twicer ®   28-Feb-2023 10:50
Guidance of Welders Qualification Tests
Year: 2022
Author: ClassNK
Pages count: 32
Description: Welders and welding operators (hereinafter referred to as “welder”) engaged in welding works for
hull construction, machinery, equipment, etc. of ships registered in classification Society are to be
qualified in accordance with classification Society’s Rules. The qualification of welders is to be
controlled and maintained properly under the responsibility of shipyard or manufacturer who
employs them.
This guidance sets forth the outline of necessary procedures and tests for welder’s qualification in
accordance with Part M of Rules for the Survey and Construction of Steel Ships (hereinafter
referred to as “NK Rules”).
Guidance of Welders Qualification Tests ClassNK 2022.pdf
Guidelines for Excellent Living and Working Environment - ClassNK [2024, PDF]
Rules for Building and Classing Steel Vessels (2018), Complete set - ABS [2018, PDF]
Rules for Building and Classing Marine Vessels JAN Complete Set - American Bureau of Shipping - ABS ...
Guidelines for Ships Using Alternative Fuels - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2022, PDF...
Guidelines for Cyber Resilience of Ships - ClassNK [2024, PDF]
Guidelines for Offshore Access Systems - ClassNK [2024, PDF]
Shipbuilding and Repair Quality Standard (Rec.47) Corrected - IACS [2025, PDF]
Guidelines for Installations for Infection Control (Edition 1.0) - ClassNK [2022, PDF]
The time now is: Today 18:04
