twicer ®   07-Sep-2024 09:43
Guidelines for Ships Using Alternative Fuels
Year: 2024
Author: ClassNK
Genre: Textbook, Guide
Edition: 3.0 (July 2024)
Pages count: 269
Description: the Guidelines will provide practical guidance for shipyards, manufacturers, shipowners,
managers, and operators looking to prepare their fleets for a safer and greener future. Its purpose is to
simply provide support to designers with respect to the current requirements, and it will be amended as
may be deemed necessary in accordance with any changes made to the IGF Code by the IMO as well as in
consideration of any new technologies introduced in the future.
These Guidelines have been independently established by the Society with reference to SOLAS, the IGC Code
and the IGF Code, taking into account the nature of each gas or other low-flashpoint fuels (hereinafter referred
to as “Alternative fuels”) to minimize risks to ships, crew, and the environment associated with the use of
alternative fuels, and setting standards for equipment, control, and monitoring devices for ships using alternative
fuels.
Structure of the Guidelines:
These Guidelines contain Part A, B, C, D and Annex 1.
Part A contains safety requirements for ships using methanol/ethanol.
Part B contains safety requirements for ships using LPG.
Part C contains safety requirements for ships using ammonia.
Part D contains safety requirements for ships using hydrogen.
Annex 1 contains the requirements for examining, by application, the status of consideration of ships that do not use gases or
other low-flashpoint fuels at the time of their construction but are designed and partially equipped for the future use of such fuels.
Guidelines for Ships Using Alternative Fuels.pdf
Download [7 KB]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2022, PDF...
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2024, PDF...
GUIDE FOR USE OF LITHIUM BATTERIES IN THE MARINE AND OFFSHORE INDUSTRIES - ABS [2018, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl / Ethyl Alcohol / LPG / Ammonia) - ClassNK [202...
Guidelines for Ships Using Alternative Fuels - ClassNK [2026, PDF]
Guidelines for Offshore Access Systems - ClassNK [2024, PDF]
Guidelines for Remote Survey - ClassNK [2025, PDF]
LR Summary Report for the IMO Ship Design and Construction (SDC 8) - Lloyd’s Register [2022, PDF]
Guidelines for Cyber Resilience of Ships - ClassNK [2024, PDF]
LR Summary Report for the IMO Ship Systems and Equipment Sub-Committee (SSE 9) - Lloyd’s Register [2...
The time now is: Today 17:39
