twicer ®   07-Sep-2024 09:22
Guidelines for Offshore Access Systems
Year: 2024
Author: ClassNK
Edition: 1.0 (July 2024)
Pages count: 28
Description: ClassNK has compiled this Guidelines for Offshore Access Systems (hereinafter referred to as
the “Guideline”) to provide guidance with respect to the construction, testing and installation of personnel transfer
arrangements for ships applying the IP Code.
It is ClassNK’s hope that this Guideline will lead to increased safety
for those engaged to work on offshore facilities not only when they are on board the facilities themselves but also
when being transported to and from such facilities.
Offshore access systems.pdf
Guidelines for Ships Using Alternative Fuels - ClassNK [2024, PDF]
Wind Assisted propulsion Systems for ships - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2022, PDF...
Guidelines for Excellent Living and Working Environment - ClassNK [2024, PDF]
Guidelines for Underwater Noise from Ships - ClassNK [2023, PDF]
Guidance of Welders Qualification Tests - ClassNK [2022, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl / Ethyl Alcohol / LPG / Ammonia) - ClassNK [202...
Guidelines for Digital Smart Ships - ClassNK [2021, PDF]
Guidelines for Cyber Resilience of Ships - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2024, PDF...
The time now is: Today 03:32
