twicer ®   28-Apr-2022 07:46
Guidelines for Installations for Infection Control (Edition 1.0)
Year: 2022
Author: ClassNK
Genre: Normative document
Pages count: 24
Description: For ships engaged in international voyages, the primary control measure adopted to date against
the spread of infectious diseases has been quarantines. For all intents and purposes, however, quarantines
do very little to prevent the transmission of infectious diseases among individuals on board a ship
due to the nature of onboard accommodation environment that makes it extremely difficult to control
their spread.
This Guidelines for Installations for Infection Control (hereinafter referred to as the
“Guidelines”) applies to ships (excluding passenger ships) registered with the Nippon Kaiji Kyokai
(hereinafter referred to as “the Society”) that have implemented means to minimise the spread of
infection diseases on board ship (hereinafter referred to as “infection control measures”) and for
which applications for the affixation of special class notation to classification characters are
submitted.
The infection control measures specified in this Guidelines primarily apply to the installations,
systems, equipment, and other means adopted by ships. This Guidelines also applies to the
provision and use of medicines as well as medical devices and equipment not specifically
referenced within, but such matters are also to be considered separately.
NKClass_Guidelines for Installations for Infection Control 2022.pdf
Download [1 KB]
Guidelines for Excellent Living and Working Environment (Edition 1.0) - ClassNK [2022, PDF]
Guidelines for Advanced Safety Measures (Edition 1.0) - ClassNK [2022, PDF]
Guidelines for the Inventory of Hazardous Materials - ClassNK [2023, PDF]
Guidelines for Excellent Living and Working Environment - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl / Ethyl Alcohol / LPG / Ammonia) - ClassNK [202...
An Implementation Guide for the Management of COVID-19 on board cargo ships and fishing vessels - WH...
Guidelines for Ships Using Alternative Fuels - ClassNK [2026, PDF]
Guidelines for Hull Monitoring - ClassNK [2021, PDF]
Guidelines for Offshore Access Systems - ClassNK [2024, PDF]
Guidelines for Ships Using Alternative Fuels (Methyl/Ethyl Alcohol/LPG/Ammonia) - ClassNK [2022, PDF...
The time now is: Today 04:12
