twicer ®   19-Oct-2025 10:38
Shipbuilding and Repair Quality Standard (Rec.47)
Year: 2025
Author: IACS
Publisher: IACS
Edition: Rec.No.47 Rev.11 2025
Pages count: 68
Description: This publication provides guidance on shipbuilding quality standards for hull structures during new construction and offers remedial criteria where these standards are not met. Applicable to conventional merchant ship types and structures fabricated from normal and higher strength steels, it outlines the acceptable workmanship ranges and inspection tolerances that support consistent and safe construction practices. It is intended for use where no established national or shipbuilding standards have been adopted by the Classification Society.
This standard sets out shipbuilding quality requirements for hull structures during new construction, including criteria for corrective measures when those requirements are not achieved. It also includes repair quality standards for existing ships. This standard is intended for situations where no recognised shipbuilding or national standards are in place.
It includes requirements for general construction practices, gas cutting, fabrication, alignment, welding joint details and remedial actions. Separate provisions cover repairs, including general repair requirements, welding, material use and qualification of personnel involved in repair work.
PART A Shipbuilding and Remedial Quality Standards for New Construction
References
Standards
1. Scope
2. General requirements for new construction
3. Qualification of personnel and procedures
4. Materials
5. Gas Cutting
6. Fabrication and fairness
7. Alignment
8. Welding Joint Details
9. Remedial
PART B Shipbuilding and Repair Quality Standard for Existing Ships
References
Standards
1. Scope
2. General requirements for repairs and repairers
4. Materials
5. General requirements to welding
6. Repair quality standard
IACS Shipbuilding and Repair Quality Standard (Rec.47).pdf
Shipbuilding and Repair Quality Standard (Rec.47) Corrected - IACS [2025, PDF]
ABS - Guidance Note on Surveys During Construction of Membrance Tank LNG Carriers - ABS [2008, PDF]
Guidelines for Designing Cyber Security Onboard Ships - ClassNK [2020, PDF]
General Dry Cargo ships - Guide for surveys, assesment and repair of hull structures - IACS [2016, P...
Surveyor’s Glossary Hull Terms & Hull Survey Terms - IACS [2003, PDF]
IICL: General Guide for Refrigerate Container Inspection and Repair, 4th Edition - IICL [2016, PDF]
Surveyor’s Glossary Hull Terms & Hull Survey Terms - IACS [2018, PDF]
MSC Circ.1175 Guidance on Shipboard Towing and Mooring Equipment - IMO Circular [2005, PDF]
Rules For Building And Classing Single Point Moorings - ABS [2021, PDF]
Double Hull Oil Tankers - Guide for Survey, Assessment and Repair of Hull Structures - IACS [2007, P...
The time now is: Today 17:52
