twicer ®   23-Oct-2025 17:54
Shipbuilding and Repair Quality Standard (Rec.47) Corrected
Year: 2025
Author: IACS
Publisher: IACS
Edition: Rec. 1996/Rev.10 2021/Correction 1 October 2025
ISBN: 1917308588
Pages count: 68
Description: This publication provides guidance on shipbuilding quality standards for hull structures during new construction and offers remedial criteria where these standards are not met. Applicable to conventional merchant ship types and structures fabricated from normal and higher strength steels, it outlines the acceptable workmanship ranges and inspection tolerances that support consistent and safe construction practices. It is intended for use where no established national or shipbuilding standards have been adopted by the Classification Society.
This standard sets out shipbuilding quality requirements for hull structures during new construction, including criteria for corrective measures when those requirements are not achieved. It also includes repair quality standards for existing ships. This standard is intended for situations where no recognised shipbuilding or national standards are in place.
It includes requirements for general construction practices, gas cutting, fabrication, alignment, welding joint details and remedial actions. Separate provisions cover repairs, including general repair requirements, welding, material use and qualification of personnel involved in repair work.
* PART A Shipbuilding and Remedial Quality Standards for New Construction
References
Standards
1. Scope
2. General requirements for new construction
3. Qualification of personnel and procedures
4. Materials
5. Gas Cutting
6. Fabrication and fairness
7. Alignment
8. Welding Joint Details
9. Remedial
*PART B Shipbuilding and Repair Quality Standard for Existing Ships
References
Standards
1. Scope
2. General requirements for repairs and repairers
4. Materials
5. General requirements to welding
6. Repair quality standard
Rec.47 Shipbuilding and Repair Quality Standard Rev.10 Corr.1 Oct 2025 IACS.pdf
Download [1 KB]
Guidance Notes on Composite Repairs of Steel Structures and Piping - ABS [2021, PDF]
Guide For Materials and Welding for Stainless Steels, 2019 - ABS [2018, PDF]
General Dry Cargo ships - Guide for surveys, assesment and repair of hull structures - IACS [2016,…
Guidance of Welders Qualification Tests - ClassNK [2022, PDF]
Review of Current Practices of Fracture Repair Procedures for Ship Structures - Ship Structure…
Welding: Principles and Applications - Larry Jeffus [2017, PDF]
IICL: General Guide for Refrigerate Container Inspection and Repair, 4th Edition - IICL [2016, PDF]
Tanker Safety Guide (Liquefied Gas) - ICS [1995, PDF]
The time now is: Today 16:05
