twicer ®   01-Nov-2021 23:39
Guide for Means of Access to Tanks and Holds for Inspection
Year: 2021
Author: ABS
Pages count: 109
Description: The ability to survey/inspect the condition of a vessel is a principal means to help verify that the vessel’s
structure is maintained to comply with applicable requirements. These surveys/inspections assist Owners;
flag Administrations and classification societies in determining that vessels are free from damage and that
material thickness are within established limits. For surveys/inspections to be carried out safely and
effectively, suitable means of access to the vessel’s structure is required.
The most recent adoptions to IMO legislation (SOLAS Reg. II-1/3-6) have established new requirements
for means of access. Throughout the life of a vessel, this access enables overall and close-up inspections
and material thickness measurements of the vessel’s structures. These means of access may be used by
Flag Administrations, classification societies, vessel personnel and others as necessary.
ABS has prepared the Guide for
Means of Access to Tanks and Holds for Inspection. This Guide provides additional information, via text
and graphics, about the means of access requirement’s interpretation and application, as well as the criteria
for the PMA and PMA + notations.
Release Date: September, 2021
Guide for Means of Access to Tanks and Holds for Inspection ABS 2021.pdf
ABS Guide for Means of Access to Tanks and Holds for Inspection - ABS [2024, PDF]
Ship Structural Access Manual - IACS [2024, PDF]
Ship Structure Access Manual - IACS [2005, PDF]
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers - ABS [2021, PDF]
Ship Structural Access Manual - IACS [2019, PDF]
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers - ABS [2022, PDF]
Guide for Coating Maintenance & Repairs for Ballast Tanks on Oil Tankers - IACS [2015, PDF]
The time now is: Today 15:14
