twicer ®   18-Dec-2023 12:44
ABS Guide for Means of Access to Tanks and Holds for Inspection
Year: 2024
Author: ABS
Edition: January, 2024
Pages count: 108
Description: The maritime industry has long recognized that periodic surveys/inspections are the primary means for
verifying that a vessel’s structure is maintained within applicable requirements throughout its operational
life. These surveys/inspections help confirm that the vessel is free from damage such as cracks, buckling,
corrosion and overloading, and that material thickness are within established limits. For surveys/
inspections to be carried out effectively, suitable means of access to the vessel’s structure are required.
To address the issue of suitable access, the Maritime Safety Committee (MSC) adopted the following
resolutions into SOLAS Regulation II-1/3-6 on “Access to and within spaces in the cargo area of oil
tankers and bulk carriers”.
In support of the Statutory and IACS guidance, ABS has prepared the Guide for Means of Access to Tanks
and Holds for Inspection. This Guide provides graphical illustrations and additional textual clarification of
the means of access requirements. The goal is to improve the comprehension and application of the
Statutory and IACS guidance.
ABS Guide for Means of Access to Tanks and Holds for Inspection.pdf
Guide for Means of Access to Tanks and Holds for Inspection - ABS [2021, PDF]
Guide for Special Loading of Ore and Ore/Oil Carriers - ABS [2023, PDF]
Ship Structure Access Manual - IACS [2005, PDF]
The Inspection, Maintenance and Application of Marine Coating Systems - American Bureau of Shipping ...
Guide for Planning Gas Trials for LNG Vessels - SIGTTO [2008, PDF]
Ship Structural Access Manual - IACS [2019, PDF]
CONTAINER SHIPS. Guidelines for Surveys, Assessment and Repair of Hull Structures - The Internationa...
Guide for Vessels Intended to Carry Compressed Natural Gases in Bulk - ABS [2020, PDF]
Guidance Notes οn the Use οf Remote Inspection Technologies - ABS [2019, PDF]
The time now is: Today 12:52
