twicer ®   07-Nov-2021 15:01
Allowable thickness diminution for Hull Structure
Year: 2021
Author: DNV
Genre: Class Guideline
Pages count: 38
Description: A vessels scantlings are based on requirements according to the rules for classification
in force at the 'date of contract for construction'.
During the life time of the vessel the structure will deteriorate due to corrosion. The corrosion will vary
depending on a number of factors, such as material, environment, corrosion protection system, structural
element type, etc. The level of deterioration shall be evaluated by surveys and thickness measurements.
The objective of this class guideline is to provide the user with the acceptance criteria for the corrosion
deterioration of hull structures.
DNV Guideline_Allowable thickness diminution for hull structure.pdf
Download [1 KB]
Ultrasonic thickness Measurements of Ships - DNV [2018, PDF]
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
Guide for Means of Access to Tanks and Holds for Inspection - ABS [2021, PDF]
Guide for Vessels Intended to Carry Compressed Natural Gases in Bulk - ABS [2020, PDF]
Rules of Bureau Veritas (BV) - [2018, PDF]
Rules for the Classification and Construction of Sea-Going Ships - Russian Maritime Register of Ship...
Guidance Notes on Maintenance and Repair of Protective Coatings - ABS [2017, PDF]
Guide for Building and Classing Liftboats - ABS [2022, PDF]
The time now is: Today 18:31
