twicer ®   01-Nov-2021 22:30
Guide for Slamming Loads and Strength Assessment for Vessels
Year: 2021
Author: ABS
Pages count: 50
Description: This Guide describes a slamming strength assessment procedure for vessels. Typically, there are three
types of slamming loads on commercial vessels: bottom slamming, bowflare slamming, and stern
slamming depending upon the hull geometry at the bow and stern. Upon verifying compliance with the
requirements in this Guide, optional notations may be assigned to a vessel.
A fundamental requirement of this Guide is that the scantlings of the hull structure are to be in accordance
with the criteria as specified in the ABS Rules for Building and Classing Marine Vessels (Marine Vessel
Rules). The results of this Guide are not to be used to reduce the basic scantlings obtained from the
application of the Marine Vessel Rules. That is, if the results from this Guide indicate the need to increase
any basic scantlings, the increased scantlings are to be implemented above the rule requirements.
Release Date: October, 2021
Slamming Loads and Strength Assessment for Vessels ABS 2021.pdf
Guide for Dynamic Positioning Systems November 2019 - ABS [2019, PDF]
Guide for Special Loading of Ore and Ore/Oil Carriers - ABS [2023, PDF]
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers - ABS [2021, PDF]
Guide for Alternative Requirements for Hull Construction of Vessels Intended to Carry Vehicles - ABS...
Guidance Notes on Strength Assessment of Independent Type C Tanks - ABS [2022, PDF]
Guide for Dynamic Positioning System - ABS [2021, PDF]
ABS - Guide for Dynamic Positioning Systems - ABS [2021, PDF]
Guide for Alternative Requirements for Hull Construction of Vessels Intended to Carry Vehicles (130 ...
The time now is: Today 04:55
