twicer ®   01-Nov-2021 22:57
Guide for Ballast Water Treatment
Year: 2021
Author: ABS
Pages count: 75
Description: The requirements in this Guide apply to vessels that are designed, equipped and intended to use the
treatment method for conducting ballast water management in accordance with Regulation B-3 (as
amended) of the “International Convention for the Control and Management of Ships’ Ballast Water and
Sediments, 2004 ”(Convention), the associated IMO guidelines and national regulations, addressing the use
of a ballast water management system. At the request of the owner, a vessel having a ballast water
management system (BWMS) installed for conducting ballast water management which complies fully
with the requirements of this Guide and the applicable Rules and has been installed under survey by ABS
Surveyors may be assigned the Ballast Water Treatment (BWT) or the Ballast Water Treatment Plus (BWT
+) classification notation as specified in 1/7 of this Guide.
Where a vessel is fitted with a BWMS and the BWT or BWT + notation is not being pursued, the installed
BWMS is to comply with the requirements in Sections 4 and 5 of the Guide and be verified by an ABS
Surveyor during installation.
This Guide refers to relevant international regulations and guidelines that are considered to be applicable.
While it is the intent of this Guide to be consistent with the regulations and guidelines, it is recommended
that the users of this Guide refer to the most recent text of those regulations and guidelines.
Release Date: September, 2021
Guide for Ballast Water Treatment ABS 2021.pdf
Download [6 KB]
Guide for Ballast Water Treatment - ABS [2019, PDF]
Guide for Ballast Water Exchange - ABS [2018, PDF]
Ballast Water Management Record Book requirements - DBS [2022, PDF]
Ballast Water Record Book RML-124 Rev. 2025 - Liberian Registry (LISCR) [2025, PDF]
Guide for Ballast Water Treatment - ABS [2022, PDF]
Ballast Water Management Plan [model] - Lloyd’s Register and IMO [2023, DOC/PDF]
Code For Approval Of Ballast Water Management Systems (BWMS CODE) - IMO [2018, PDF]
Ballast Water Management Plan DNV template - DNV [2017, PDF]
Technical Manual for BWMS AQ-0300-UV - Wartsila Water Systems Ltd [2016, PDF]
Ballast Water Treatment and Exchange for Ships - Alexander Olsen, Pamela Ciampolini [2024, PDF/EPUB]
The time now is: Today 05:07
