twicer ®   20-May-2025 20:51
Ship Structural Access Manual
Year: 2024
Author: IACS
Edition: Rec.90 Rev.2 November, 2024
Pages count: 18
Description: This access manual provides for safe conduct of overall and close-up inspections and thickness measurements on a regular basis throughout ship’s operational life, and gives necessary information and instructions for that purpose, under the provisions of SOLAS regulation II-1/3-6 adopted by resolution MSC.134(76) as amended by resolution MSC.151(78) and the Technical provisions for means of access for inspections adopted by resolution MSC.133(76) as amended by resolution MSC.158(78).
Ships should be designed and built with due consideration as to how they will be surveyed by flag State inspectors and classification society surveyors during their in-service life and how the crew will be able to monitor the condition of the ship. Without adequate access, the structural condition of the ship can deteriorate undetected and major structural failure can arise. A comprehensive approach to design and maintenance is required to cover the whole projected life of the ship.
Ship Structural Access Manual IACS Rec.90 Rev.2 2024.pdf
Download [397 B]
Ship Structure Access Manual - IACS [2005, PDF]
Ship Structural Access Manual - IACS [2019, PDF]
Guide for Means of Access to Tanks and Holds for Inspection - ABS [2021, PDF]
ABS Guide for Means of Access to Tanks and Holds for Inspection - ABS [2024, PDF]
Shipboard Oil Pollution Emergency Plan - Synergy Maritime Pvt. Ltd. [2017, PDF]
IMSBC Code and Supplement (Incorporating Amendment 07-23) 2023 Edition - IMO [2023, PDF]
Training Manual for Life Saving - YANGFAN GROUP CO.-ZHEJIANG [2003, PDF]
Container Cargo Operation Manual - Synergy Maritime Pvt. Ltd. [2023, PDF]
Procedures for Port State Control - IMO [2025, PDF]
Code for the Construction and Equipment of Ships Carrying Dangerous Chemicals in Bulk (BCH Code) - I...
The time now is: Today 09:49
