virtual ®   25-Nov-2018 23:24
Guides to Good Practice in Corrosion Control, Coating for the Protection of Structural Steelwork
Year: 2000
Author: NPL
Pages count: 16
Description: The purpose of this guide is to explain, in terms of modern
concepts, the basic requirements for protecting structural
steel with paint and metallic coatings, the systems commonly
used and their significance in relation to the protective
properties required. The emphasis is on the protection of
onshore structures, such as buildings, bridges, factories, and
industrial plants in which the process environment contributes
to the corrosion hazard.
Reference is made to appropriate standards which deal with
alternative protective systems in detail. These documents are
a very valuable source of information and it is recommended
that they should be consulted freely at an early stage in the
selection of a protective coating.
Coating for the Protection of Structural Steelwork.pdf
Download [549 B]
Marine and Offshore Corrosion - Kenneth A. Chandler [1985, PDF]
The Inspection, Maintenance and Application of Marine Coating Systems - American Bureau of Shipping ...
Corrosion Control for Offshore Structures: Cathodic Protection and High-Efficiency Coating - Ramesh ...
Protective Coating Corrosion Control [2024, MP4]
Hempel Paint Catalogue - Hempel [2006, HTML]
Guidance Notes on Maintenance and Repair of Protective Coatings - ABS [2017, PDF]
Cathodic Corrosion Protection Systems - A Guide for Oil and Gas Industries - A Guide for Oil and Gas...
Corrosion and Protection of Marine Engineering Materials - Yanhua LEI (Edit [2023, PDF]
The time now is: Today 20:27
