abi_mans ®   26-Jan-2022 23:50
Marine and Offshore Corrosion
Year: 1985
Author: Kenneth A. Chandler
Genre: Reference book
Publisher: Butterworths
Edition: 1st
ISBN: 9781483192253
Pages count: 420
Description: Marine and Offshore Corrosion describes the principles of effective corrosion control treatments in marine environments, with emphasis on economic solutions to corrosion. The book explains chemical or electrochemical reaction of an alloy with its environment leading to corrosion, and mechanical loss of the metal by erosion, abrasion, or wear resulting also in corrosion. A main consideration of erosion control that the engineer should look into is the economic side. Other considerations that he should investigate are the strength of a structure, time for construction, availability of materials, and costs. The book also discusses the marine environment consisting of sea water, temperature fluctuations, dissolved gases, hydrogen sulphide, ammonia, carbon dioxide, electrical conductivity, fouling. The text describes the selection of materials to be used in marine environments, surface preparation of steel before painting, the type of paint, and metallic coatings. Some of the factors in selecting coating systems are: cost and estimated life before the first scheduled maintenance, adhesion properties, moisture tolerance, elasticity, chemical resistance, impact resistance, bacterial resistance. The factors affecting maintenance include environmental conditions, quality of initial protection applied, type of structure, as well as the design and purpose of the structure. The book has been prepared for engineers and designers who are not corrosion specialists but have to deal with marine corrosion problems as part of their day-to-day professional activities. The text will also turn out to be useful for engineers with general interest in structure, building, or machinery maintenance specially those located near coastal areas.
Chapter 1 Introduction: The Control of Corrosion in Marine Environments
Chapter 2 Principles of Corrosion
Chapter 3 Marine Environments
Chapter 4 Forms of Corrosion
Chapter 5 Ferrous Alloys
Chapter 6 Non-Ferrous Metals and Alloys
Chapter 7 Design
Chapter 8 The Selection of Materials for Marine Environments
Chapter 9 Protective Coatings for Steelwork—Surface Preparation of Steel Before Painting
Chapter 10 Paint Coatings
Chapter 11 Metallic Coatings
Chapter 12 Attaining the Potential Performance of Coating Systems in Marine Environments
Chapter 13 The Selection of Coating Systems for Marine Environments
Chapter 14 Maintenance Painting
Chapter 15 Control and Treatment of the Environment
Chapter 16 Cathodic Protection
Chapter 17 Offshore Structures for Oil and Gas Production
Chapter 18 Protective Coating of Ships
Chapter 19 Steel Piling
Chapter 20 Reinforced Concrete, Wood and Plastics
Chapter 21 Testing and Monitoring
Download [18 KB]
Guides to Good Practice in Corrosion Control, Coating for the Protection of Structural Steelwork -…
Ship Construction (Chief Mate Course) - Captain S.A Hosseini [20XX, PDF]
Marine Corrosion of Stainless Steels - Chlorination and Microbial Effects - Working Party on Marine…
Cathodic Protection Corrosion Control System [2024, MP4]
LaQue’s Handbook of Marine Corrosion - David A. Shifler [2022, PDF]
Marine applications of advanced fibre-reinforced composites - Graham-Jones J., Summerscales J.…
Designing Cathodic Protection Systems for Marine Structures and Vehicles - Various authors [1999,…
Corrosion for Marine and Offshore Engineers - J. C. ROWLANDS, [1981, PDF]
The time now is: Today 17:31
