NNT ®   26-Mar-2015 09:56
Corrosion Control for Offshore Structures: Cathodic Protection and High-Efficiency Coating
Year: 2014
Author: Ramesh Singh
Genre: Practical guide
Publisher: Elsevier Inc.
Edition: 1st
ISBN: 978-0-12-404615-3
Pages count: 224
Description: A variable game changer for those companies operating in hostile, corrosive marine environments, Corrosion Control for Offshore Structures provides critical corrosion control tips and techniques that will prolong structural life while saving millions in cost. In this book, Ramesh Singh explains the ABCs of prolonging structural life of platforms and pipelines while reducing cost and decreasing the risk of failure. Corrosion Control for Offshore Structures places major emphasis on the popular use of cathodic protection (CP) combined with high efficiency coating to prevent subsea corrosion.
This reference begins with the fundamental science of corrosion and structures and then moves on to cover more advanced topics such as cathodic protection, coating as corrosion prevention using mill applied coatings, field applications, and the advantages and limitations of some common coating systems. In addition, the author provides expert insight on a number of NACE and DNV standards and recommended practices as well as ISO and Standard and Test Methods. Packed with tables, charts and case studies, Corrosion Control for Offshore Structures is a valuable guide to offshore corrosion control both in terms of its theory and application.
[Ramesh_Singh]_Corrosion control for offshore structures-2015
Download [4 KB]
LaQue’s Handbook of Marine Corrosion - David A. Shifler [2022, PDF]
Guides to Good Practice in Corrosion Control, Coating for the Protection of Structural Steelwork -…
Marine Corrosion and Cathodic Protection - Chris Googan [2022, PDF]
Cathodic Corrosion Protection Systems - A Guide for Oil and Gas Industries - A Guide for Oil and…
Arc Welding Processes Handbook - Ramesh Singh [2021, PDF]
Hydroblasting and Coating of Steel Structures - Andreas Momber [2003, PDF]
Design of Marine Risers with Functionally Graded Materials - SRINIVASAN CHANDRASEKARAN [2021, PDF]
Pipelines and Risers - Yong Bai [2001, PDF]
Designing Weldments - Ramesh Singh [2022, PDF]
Essential Guide to Tanker Ship Coatings - Types, Maintenance and Best Practices - Britannia P…
The time now is: Today 14:18
