virtual ®   07-Oct-2019 22:38
Guidance Notes on Maintenance and Repair of Protective Coatings
Year: 2017
Author: ABS
Pages count: 50
Description: A protective coating is the most efficient way to protect steels and preserve structural strength. However, the coating can deteriorate over time during service. In order to maximize service life with reduced life-cycle cost, it is critical to maintain and repair the coating at an early stage, before accelerated corrosion due to coating deterioration occurs. It is also important for the coatings to comply with the IMO Performance Standards of Protective Coatings (IMO PSPC) for the goal, as a minimum, of 15 years of useful coating life in “GOOD” condition. These Guidance Notes provide guidelines of coating maintenance and restoration of ballast tanks and cargo oil tanks in order to reach the PSPC goal.
Coating_Maintenance_GN_e-May17.pdf
Coating Maintenance– Guidelines for Coating Maintenance & Repairs for Ballast Tanks and Combined…
Guide for Coating Maintenance & Repairs for Ballast Tanks on Oil Tankers - IACS [2015, PDF]
Inspection Grading for Hull Inspection Maintenace Program (HIMP) - American Bureau of Shipping…
Guides to Good Practice in Corrosion Control, Coating for the Protection of Structural Steelwork -…
Wooden Boat Restoration & Repair - WEST SYSTEM® epoxy [2003, PDF]
Prevention of corrosion on board ships - IMO [2010, PDF]
Guidance Notes On Ship Vibration - ABS [2006, PDF]
The time now is: Today 18:37
