twicer ®   04-Nov-2021 17:11
Corrosion Protection of Ships
Year: 2021
Author: DNV
Genre: Class Guidelines
Pages count: 66
Description: The aim of this guideline is to indicate different recognised methods for corrosion protection and surface
preparation of ships and systems installed on ships, with emphasis on tanks and holds. For ballast tanks,
double side skin space of bulk carriers, void space, cargo oil tanks and permanent means of access, this
guideline refers to the IMO and IACS regulations, resolutions, circulars and interpretations.
Use of cathodic protection is recommended in combination with coating on surfaces submerged in seawater,
e.g. sacrificial anodes in ballast tanks.
The guideline is not mandatory for classification use but for assisting in the selection of effective corrosion
protection systems by shipyards and owners.
Definitions and terms, properties and standards for protective coatings, a check list for coating inspectors,
materials and corrosion resistance, surface preparation of steel, and coating condition evaluation on existing
ships are briefly reviewed.
Corrosion protection of ships_DNV 2021.pdf
Download [995 B]
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - Interna...
IACS Bulk Carriers - Guidelines for Survey, Assessment and Repair of Hull Structures - IACS [2017, P...
Bulk Carriers: Guidelines for Surveys Assessment and Repair of Hull Structure - CCS [2014, PDF]
Double Hull Oil Tankers - Guide for Survey, Assessment and Repair of Hull Structures - IACS [2007, P...
ABS Guide for Means of Access to Tanks and Holds for Inspection - ABS [2024, PDF]
Cathodic Corrosion Protection Systems - A Guide for Oil and Gas Industries - A Guide for Oil and Gas...
Marine Corrosion and Cathodic Protection - Chris Googan [2022, PDF]
Cathodic Protection Corrosion Control System [2024, MP4]
CONTAINER SHIPS. Guidelines for Surveys, Assessment and Repair of Hull Structures - The Internationa...
The time now is: Today 22:12
