sugarspicesatya ®   28-Apr-2024 08:50
Cathodic Corrosion Protection Systems - A Guide for Oil and Gas Industries
Year: 2014
Author: A Guide for Oil and Gas Industries
Genre: Textbook
ISBN: 978-0-12-800274-2
Pages count: 466
Description: This engineering book covers the minimum requirements for anodes (high-
silicon iron, graphite, magnetite) for use in impressed current CP systems. It specifies
the composition, materials, manufacture, properties, inspection, and testing for
high-silicon iron, graphite, and magnetite anodes. Moreover, this book revised survey requirements to ascertain that corrosion
control systems installed on buried or submerged structures are properly designed,
operated, and effectively maintained. This book also provides information concerning
techniques, equipment, measurements, and test methods used in field application. It
deals with inspection of coatings in conjunction with CP for its efficiency on current
distribution.
n/a
Cathodic_corrosion_protection_systems.pdf
Download [8 KB]
Impress Current Cathodic Protection System Manual - HWASEUNG R&A (Wilson Walton Korea) [2012, PDF]
Cathodic Protection Corrosion Control System [2024, MP4]
Marine Corrosion and Cathodic Protection - Chris Googan [2022, PDF]
Marine applications of advanced fibre-reinforced composites - Graham-Jones J., Summerscales J. [2016...
Guidance Notes on Cathodic Protection of Ships - ABS [2017, PDF]
Furuno Radar Operators Manual FAR-2107(-BB,-D) - FAR-2807(-D) Series - Furuno [2011, PDF]
Corrosion Inspection and Monitoring - Pierre R. Roberge [2007, PDF]
The time now is: Today 14:28
