Ferreirolo ®   10-Feb-2021 22:43
Rules For Building And Classing Single Point Moorings
Year: 2021
Author: ABS
Genre: Normative document
Publisher: American Bureau of Shipping ABS
Pages count: 92
Description: This edition of the ABS Rules for Building and Classing Single Point Moorings (SPMs) primarily reflects changes in format and references to ABS and other standards that have occurred since the previous edition was issued.
Changes to the technical criteria include revisions made to other pertinent ABS Rules that are the basis of SPM criteria; such as, the introduction of an adjustment factor (Q) to account for higher strength steels in the determination of buoy scantlings. Also the section on Moorings and Anchoring Section (3-4-1, herein) has been updated to reflect industry practice and to specifically allow the option to use the criteria found in the ABS Rules for Building and Classing Floating Production Installations for this topic.
PART 1 (1 January 2008)
For the 2008 edition, Part 1, "Conditions of Classification" was consolidated into a generic booklet, entitled Rules for Conditions of Classification – Offshore Units and Structures (Part 1) for all vessels other than those in offshore service. The purpose of this consolidation was to emphasize the common applicability of the classification requirements in "Part 1" to ABS-classed vessels, other marine structures and their associated machinery, and thereby make "Conditions of Classification" more readily a common Rule of the various ABS Rules and Guides, as appropriate.
Thus, this supplement specifies only the unique requirements applicable to single point moorings. This supplement is always to be used with the aforementioned Rules for Conditions of Classification – Offshore Units and Structures (Part 1).
spm-rules-jan21.pdf
Download [1012 B]
Guide for Vessels Operating In Low Temperature Environments - ABS [2024, PDF]
Guide for Slamming Loads and Strength Assessment for Vessels - ABS [2021, PDF]
ABS - Rules for Building and Classing - Single Point Moorings - ABS [2022, PDF]
ABS - Rules for Building and Classing Marine Vessels 2022-Part 5A-5B-Specific Vessel Types IACS CSR ...
Requirements for Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carr...
Guidance Notes On Ship Vibration - ABS [2006, PDF]
Common Structural Rules for Double Hull Oil Tankers - ABS + DNV + Lloyd’s Register [2004, PDF]
Requirements for Building and Classing Floating Offshore Liquefied Gas Terminals - ABS [2024, PDF]
The time now is: Today 23:31
