lb007 ®   14-Oct-2021 15:02
MSC Circ.1175 Guidance on Shipboard Towing and Mooring Equipment
Year: 2005
Author: IMO Circular
Publisher: IMO
Quality: OCR without errors
Pages count: 11
Description: This circular is intended to provide standards for the design and construction of shipboard fittings and supporting hull structures associated with towing and mooring, which Administrations are recommended to implement. The provisions of this guidance do not require tow lines nor mandate standards for mooring lines onboard the ship.
twicer   15-Oct-2021 14:57
dated 9 December 2020
Attachments MSC.1-Circ.1175-Rev.1.pdf (485 KB, Downloaded: 10 times)
virtual   15-Oct-2021 20:29
MSC Circ.1175 of 2005 is outdated
new MSC Circ.1175
REVISED GUIDANCE ON SHIPBOARD TOWING AND MOORING EQUIPMENT MSC.1/Circ.1175/Rev.1∗ 9 December 2020
Recommendations for Ships’ Fittings for Use with Tugs: With Particular Reference to Escorting and Ot...
Recommendations For Equipment Employed in the Bow Mooring of Conventional Tankers at Single Point Mo...
Mooring Equipment Guidelines 3’d Edition - OCIMF [PDF]
Intertanko - Guidance Booklet on Seafarers´ hours of work and rest - INTERTANKO [2008, PDF]
Handbook Guidance on implementing the MLC (2006) and Social Security for Seafarers - ILO [2012, PDF]
Military Float Bridging Equipment - Department of the Army, USA [1988, PDF]
Guidance on Mooring System Management Plans (MSMP) - INTERTANKO [2019, PDF]
Procedures for Port State Control - IMO [2025, PDF]
ECDIS - Guidance for Good Practice - IMO [2022, PDF]
  • Topic closed
The time now is: Today 01:45
