twicer ®   13-Nov-2021 09:35
Surveyor’s Glossary Hull Terms & Hull Survey Terms
Year: 2018
Author: IACS
Edition: Rev.1 October 2018
Pages count: 22
Description: This Surveyor’s Glossary of Hull Terms is intended as a guide to improve the standardization
of survey reporting. It is recommended that the listed terms for hull structural elements are
used throughout report narratives.
The Glossary also includes definitions of common hull survey terms that are applicable for
surveys of hull structures and reporting.
All parties involved in the review of classification survey reports should have this Glossary
available to assist with correct interpretation of the report narratives.
Surveyor’s Glossary
Surveyor’s Glossary Hull Terms & Hull Survey Terms Rec.82 2018.pdf
Download [1 KB]
Surveyor’s Glossary Hull Terms & Hull Survey Terms - IACS [2003, PDF]
General Dry Cargo ships - Guide for surveys, assesment and repair of hull structures - IACS [2016, P...
Bulk Carriers: Guidelines for Surveys Assessment and Repair of Hull Structure - CCS [2014, PDF]
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
Double Hull Oil Tankers - Guide for Survey, Assessment and Repair of Hull Structures - IACS [2007, P...
Double Hull Oil Tankers - Guidelines for Surveys, Assessment and Repair of Hull Structures - Interna...
General Dry Cargo Ships – Guidelines for Surveys, Assessment and Repair of Hull Structures - IACS [2...
Confined Space Safe Practice, Rev. 3 - IACS [2018, PDF]
Confined Space Safe Practice (Rec.72) - IACS [2025, PDF]
Shipbuilding and Repair Quality Standard (Rec.47) Corrected - IACS [2025, PDF]
The time now is: Today 22:50
