twicer ®   15-Nov-2023 14:19
Guidelines for Underwater Noise from Ships
Year: 2023
Author: ClassNK
Edition: 1.0
Pages count: 38
Description: In advance of the IMO enacting any mandatory regulations regarding the underwater noise from
ships, ClassNK decided to forge ahead and issue its own Guidelines for Underwater Noise from
Ships to provide guidance to its clients on the matter. This Guidelines includes various examples of
underwater noise countermeasures, measurement methods and threshold values, and also specifies
relevant class notation for ships according to their underwater noise levels which comply with its
requirements.
Since the IMO deliberations are currently ongoing and since other relevant authorities and
organisations are also expected to issue their own regulations and guidelines in the future, ClassNK
intends to continuously monitor such developments and amend this Guidelines accordingly to keep
it as current as possible.
It is ClassNK’s hope that this Guideline will help its clients to better understand the impact of
underwater noise and to adopt appropriate measures to minimise that impact as much as possible.
gl_underwater_noise_from_ships_e202310.pdf
Guidelines for Digital Smart Ships - ClassNK [2021, PDF]
Class Notation Handbook - ClassNK [2020, PDF]
Guidelines for Excellent Living and Working Environment - ClassNK [2024, PDF]
Requirements for Nuclear Power Systems for Marine and Offshore Applications - ABS [2024, PDF]
Guidelines for Exhaust Gas Cleaning System - ClassNK [2022, PDF]
Code on Noise Levels on Board Ships with Guide for Noise Survey (2014) - Lloyd’s Register + UK P&I C...
ClassNK Guidelines - ClassNK [2025, PDF]
Guide for Ballast Water Exchange - ABS [2018, PDF]
Guidelines for Direct Load Analysis and Strength Assessment - ClassNK [2023, PDF]
Guidelines for Advanced Safety Measures (Edition 1.0) - ClassNK [2022, PDF]
The time now is: Today 20:33
