Nemo ®   17-Jun-2023 05:50
OMRON CX-ONE
Year: 2023
Version: 4.60
Developer: OMRON
64-bit OS compatibility: yes
System Requirements: Windows 7/8/10/11 and .NET Framework 3.5 SP1
Crack: Serial
Description: CX-One software allows users to build, configure and program a host of devices such as PLCs, HMIs and motion-control systems and networks using just one software package with one installation and license number. This greatly reduces the complexity of the configuration and allows automation systems to be programmed or configured with minimal training.-
  • One software to support programming PLCs + HMI, networks, motion & drive, regulation & switching and sensor s
  • Common look-&-feel for configuration of all devices
  • One installation and license number for all software
  • On-line registration offers free upgrade, free libraries, FAQ and help
Explanation
Filename expansion:
Example Prg2007_0402Setup.exe
Where
Prg - component name
20 - year
07 - month
04 - version CX-ONE (4.xx)
02 - subroutine version
Explanation of file abbreviations::
Cdm - CX-CompoNetDTM
Cmn - CX-Common Components/CPS
Cmw - CX-Communications Middleware
Cnf - CX-Configurator FDT
Drv - CX-Drive
Dsn - CX-Designer
Fln - CX-FLnet
Int - CX-Integrator
MCH - CX-Motion-MCH
Mtn - CX-Motion
Mtp - CX-Motion Pro
NCF - CX-Motion-NCF
Nic - NX-IO Configurator
Ntc - NetworkConfigurator
Pfn - ProfinetDTM
Pos - CX-Position
Prg - CX-Programmer
Prt - CX-Protocol
Sim - CX-Simulator
Swt - SwitchBox Utility
Thr - CX-Thermo
HowToInstall
1) mount CXONE_V4.60.iso
2) run AutoRun.exe and install CX-ONE
3) use key from Serial.txt
4) run "C:\Program Files (x86)\OMRON\CX-One\Upgrade Utility\AutoUpdate.exe" to upgrade the installed components to the latest versions
Modules List
Install CX-One Version CX-One Ver.4.60
Install Language English
Install Region Europe, Africa, Middle East
CX-Programmer Version 9. 8. 0. 2
CX-Simulator Ver.2. O. 1. 1
SwitchBox Utility Ver.1. 7. 0.0
CX-Designer Ver.3. 7. 3. 0
CX-Integrator Ver.2. 6. 8. 0
CX-Drive Ver.3.0.0.139
CX-Motion Ver.2.39.0120
CX-Motion Pro Ver.1.4.6.012
CX-Motion-MCH Ver.2. 3. 2. 0
CX-Motion-NCF Ver.1. 9.4. 0
CX-Position Ver.2. 5. 2. 0
Face Plate Auto-Builder for NS Ver.3. 1. 1. 1
CX-Thermo Ver.4. 6. 9.0
CX-Protocol Ver.2. 0. 2. 0
CX-Process Tool Ver.5. 2.4. 1
Network Configurator Ver.3 . 6 . 9. 1
CX-ConfiguratorFDT Ver.2.54.0.2
CX-FLnet Ver.1. 1. 0. 0
NX-I0 Configurator Ver.1.2.2.1
CX-One Upgrade Utility Ver.1.3.0.14
CX-Server Ver.5.0.30.2
Common Driver Ver.5.0.30.2
TJ1 Driver Ver.1.6.2.0
Generic FINS Ethernet Driver Ver.1.1.2.0
Communications Middleware Ver.1.4.1.2
CX-ONE_V460
Download [58 KB]
cen_turion   24-Feb-2024 21:32
Hello! The version of CX-Programmer which includes curent package is 9.7.5.6 and not 9.8 . And I can't to update the softwares because needs registration on the website. Can you help please.
nerotoksin   11-Apr-2025 18:20
Hello Guys. I need serila key for Cxone 4,61 (other keys not working Version 4.61) Thank you..
OMRON CX-ONE v.4.51 - OMRON [2019-2021]
Diagnos & Programmer 3 v.2.46.1 - Scania [2021]
ChartWorld Route Converter v.1.0.0.23 - ChartWorld [2021]
Basic maintenance & programming using S7- 400 PLC [PDF]
GPS-Dongle GD-75 v.1.0.5.18 - Prolific Technology Inc. [2008]
TELchart v.3.5.32 [2011]
GMDSS VHF DSC Simulator v.1.3.4 - dscsim & ochecker [2008]
EIVA Workflow Manager v.4.6.0.4 - EIVA [2022]
The time now is: Today 13:19
