skipper3362 ®   05-Feb-2021 19:23
Diagnos & Programmer 3
Year: 2021
Version: 2.46.1
Developer: Scania
64-bit OS compatibility: yes
System Requirements: windows
Crack: N/A
Description: Scania Diagnos & Programmer 3 (SDP3) communicates with Scania vehicles and Scania industrial and marine engines.
The program is designed to ensure the operation of the electrical system in the CAN network.
The program is used for the following purposes: • troubleshooting;
• customization of customer parameters;
• calibration;
• transformations affecting the electrical system;
• software updates in control units.
Add. Information : I personally checked the performance on Windows 10 64 bit and Windows 7 32 bit.
For diagnostics, you need a VCI2 or VCI3 adapter
Installation
1. Install Adobe Reader from Adobe website.
2. Run as administrator 1.cmd. Press any key. To restart a computer. (Test Mode will always be written on the desktop)
3. Install Scania Diagnos & Programmer 3 2.46.1 and additional programs that will begin to install themselves.
4. After finishing, from the Driver folder corresponding to your Windows (x32 or x64) run _install.exe. Agree to install the unsafe driver.
5. Run Hardware ID Reader.exe and copy the code.
6. Run Protection REG.exe -> Paste the copied code into the upper wide Fingerprint field -> Click Decode Fingerprint -> Generate.
A file with the .reg extension (register data) will appear in the installation folder. We launch it and confirm the message.
7. Copy two files from the Fix folder to the folder with the installed program.
8. Run Time.exe and click the Crack button.
9. Restart your computer.
To upgrade from the previous version, follow only steps 3 and 7.
If an error occurs during installation, remove the Kvaser Can Driver WHCP and repeat step 3.
Year / Date of Release : 2021
Version : 2.46.1
Scania SDP3 2.46.1
Download [20 KB]
Reefer Containers Training CD - Marlow Navigation [2004]
Scania DI16 Marine Engine Manuals - Scania Marine Engines [20XX, PDF]
OMRON CX-ONE v.4.60 (+CX-Programmer v9.8) - OMRON [2023]
IACS Blue Book - International Association of Classification Societies (IACS) [2024, PDF]
GlobeForms v.4.0.5.0 - Globe Wireless [201x]
User’s Guide PMI System (On-line) Pressure Analyser Version 2.0 - MAN B&W Diesel A/S [2001, PDF]
Compendium on Seamanship & Sea Accidents [2005]
e-NP Reader v.1.4 - Admiralty-UKHO [2018]
The time now is: Today 16:36
