Nemo ®   16-Jun-2016 03:21
TELchart V3.5.32
Year: 2011
Version: 3.5.32
Developer: TELKO
Windows7 compatibility: unknown
System Requirements: TelchartV3 will work on Windows XP and 7 for both 32 and 64bits platform. I have not yet tested the program on Windows 8, but for any of you who have tried it feel free to comment. I can assume that it will work on any newer version of windows, but if not, try the compatibility settings.
Crack: Not needed
Description: TELchart is an electronic charting system (ECS) for maritime use. The system makes use of vectorized marine charts from C-Map and offers a wide range of functions for navigation, route planning, safety, logging and data presentation.
The TELchart line of products have now been in continual development for more than 16 years, in close cooperation with our partner Furuno Norway's dealer network and end users from fishing, shipping and offshore vessels. In addition, the developers of TELchart themselves have direct experience with marine navigation. This have resulted in a charting system uniquely adapted to user needs while at the same time delivering unsurpassed ease of use.
TELchart maintains its user friendly interface, making the system very easy to learn. At the same time the system can offer a powerful suite of functionality tailored for a wide range of vessel types.
Thanks to NIKITON
Read first TELchart V3 by Telko AS v3.5.32 installation instructions.pdf
Telchart v3.5.32 installation
Telchart v3.5.32 installation:
1. Run "Telchart v3.5.32 setup.exe" and use the Password: MaritimeSafety
2. During installation choose the option "Install to use with CM93/3 professional+ edition"
3. Let the installation finish and install the charts.
Telchart v3.5.32 charts installation:
1. mount or extract "CM93 v3 (S57) WF766 (June 2016).iso" and copy (all files) to any folder on your PC where you like
(for example C:\CM93ed3-WF766)
2. Run C:\Program Files (x86)\cm93v3\System\GDBAdmin.exe,
show the path to CM93ed3 chart Database location (for example C:\CM93ed3-WF766), Register Database and Set it default.
3. Run C:\Program Files (x86)\cm93v3\System\LicenseAdm.exe.
4. Choose Zone 0 using “1234567890abcdef” as the key.
5. If you get a message that your license is expired or that will expire soon,
try to change this key randomly, between the codes bellow, until you get it.
0123456789abcdfe
0123456789abcdfe
1234567890abcdfe
0123456789abcdef
123abc456def7890
2222222222222222
ffffffffffffffff
9999999999999999
You can use whatever key combination you want, as long as it is made of 0-9 and/or a-f.
Enjoy!
TELchart V3 by Telko AS v3.5.32 FULL
m@riner   28-Jun-2016 21:58
Installed program and registered/licensed charts but I'm getting a message
C-Map
g_manager->init() failed
What am I missing
Thanks in advance
7
m@riner   28-Jun-2016 22:33
Ok, fixed, apparently one HAS TO COPY the database to the PC. Thanks for sharing!
principlenavigation   30-Jun-2016 19:41
Dear Jailbreak,
Many Thanks for sharing the TELCHART V.3.5.2.
Do you also have QPS QASTOR which is same as TELCHART.
Thanking you in advance.
3
matrixdu   08-Jul-2016 23:24
is there any way to change font in software some text is over bolded e.g position .....thank in advance
4
junizar   18-Nov-2016 21:16
working perfectly..many thanks...just to ask if there is any correction updates for
this thru online for free?..haha..
reza.seaman   30-Nov-2016 02:05
23873Installed program and registered/licensed charts but I'm getting a message
C-Map
What am I missing
Thanks in advance
Run Program as Administrator.
Ini   31-Dec-2016 12:25
Doesn't want to show chart databases when running GdBAdmin.exe iso file been extracted
show can't find CD , any sugestions
paxtu   09-Apr-2017 04:12
Здравствуйте, кто-то имеет более обновленную версию TECDIS.
romich7070   24-Jul-2017 19:13
Добрый вечер!можно каким то образом Transas route вставить в эту прогу?
belanra   01-Aug-2017 15:45
A gift from our Chinese friends
CM93 v3 (S57) WF820 (Week 26, July 2017).iso
https://mega.nz/#!4UBxmJwS!6sq-...watOZHtINqokYkoU
CM93 v3 (S57) WF821 (Week 27, july 2017).iso
https://mega.nz/#!FMZ0TCRT!ZSJj...5RTH6xti26QRjigY
CM93 v3 (S57) WF823 (Week 29, July 2017).iso
https://mega.nz/#!cYBS1JoA!svkn...xPELoxHsDXH2X0Lw
CM93 v3 (S57) WF824 (Week 30, July 2017).iso
https://mega.nz/#!FAon1ZKJ!UIXY...uhTPC7zP5gDPuXIU
6
KR-CON V24 v.24.0.1 - Korean Register [2026]
Marine v12.1 SP4.29 - AVEVA [2018]
eMarinersApp v.15.0.2 - eMarinersApp [2023] [Android]
MaxSea v12.6.4.1 + CM93v3 Nov-2019 charts (Windows 10 VirtualBox) - MaxSea [2019]
VisSim 6.0 + VisSim 7.0 Beta + Дополнения
Rose Point ECS v.4 - Rose Point [2020]
Spectec - AMOS2 End User Training Guide - M.Youngson [2010, PDF]
List V – List of Ship Stations and Maritime Mobile Service Identity Assignments - ITU [2025, EXE]
The time now is: Today 13:23
