zxc ®   12-Oct-2013 20:09
MarEng Learning Tool Plus [HTML version]
Year: 2007
Version: 2.0
Developer: MarEng Plus
Format: HTML
System Requirements: Windows XP/Vista/7/8
Crack: Not needed
Description: MarEng Plus - New Maritime English Learning Material Now Available!
To enjoy the new MarEng Plus material, order a copy of the Cd-Rom for free or download it on your computer from this site.
All of the MarEng Plus material is English-English and is based on language used in actual situations on board ships, in ports and elsewhere in the shipping chain. The new material will not only widen the overall user group but also motivate to learn maritime English in different levels.
MarEngPlus
How to start using packaged(zipped) MarEng Plus files
MarEng Plus package enables you to use the learning tool also in situations when there is no network connection available. Before using the package, you must unpack (unzip) it. If you don't already have zip/unzip software installed on your computer, you must first obtain suitable software. There are both free and commercial products on the market. Choose the one that suits you best.
Procedure:
Download the learning tool package on the hard disk of your computer
Create a folder with some descriptive name (e.g. MarEng Plus) and unzip the package on to it
To use learning tool locate and double-click file index.html in the folder where you unzipped the package
Alternatively you can burn the previously unpackaged contents of the folder to an empty writable CD/DVD, which makes it possible to use learning tool on any computer equipped with CD/DVD drive. If the autorun feature is enabled, the learning tool will start automatically when you insert the disk on the drive. Otherwise you must double-click file index.html located on the CD/DVD disk
Note: For using the MarEng Plus material you will need an updated version of Adobe's Flash Player
MarEng Plus is a Flash application. Flash Player is available for all major operating systems: Windows, Mac OS (Mac OS X 10.1 and newer) and Linux/Solaris systems (any modern version). System requirements are available for viewing in the following address: http://www.adobe.com/products/f...ayer/systemreqs/
Installing Flash Player on these systems is a simple procedure that requires administrator level access to the system. Simply go to the address http://get.adobe.com/flashplayer/ and it will automatically suggest the correct download. After downloading, the installation is completed as with any other program.
Note on Mac OS: Our programs are mostly tested on Flash Player 10 but only version 9 will be available prior Mac OS 10.4
Note on Linux/Solaris: On Linux or Solaris the Flash Player is normally available for installation from the operating system's own application manager (varies between distribution versions), but it is also available for download at the same URL as the Mac OS version. The page should, again, suggest the most appropriate version, but might require you to select between different installation packages. Anyone with knowledge of Linux systems should be able to select the correct package and install it in the usual way.
MarEngPlus
Download [635 KB]
Rukyn   16-Apr-2015 08:52
подскажите как его открыть ,скачал ,а запустить не пойму как
ArtGal27   16-Apr-2015 09:46
autorun.inf - правой кнопкой "запустить"
или двойной клик на index.html
MarEng Learning Tool [PC version] [2005]
Marine Engineering Diploma [2023, MP4]
GlobeForms v.4.0.5.0 - Globe Wireless [201x]
Introduction to Laser-Cutting [2022, MP4]
The COLREGs Guide - Klaas van Dokkum [2021, PDF]
ShipManager-88 v.4.0.3 (Loading/Unloading Program for 57000 DWT bulkcarrier) [2009]
Kockum Sonics Loadmaster x5 CBT v.5 - Kockum Sonics ® [2010]
KR-CON V24 v.24.0.1 - Korean Register [2026]
Rose Point ECS v.4 - Rose Point [2020]
The time now is: Today 19:29
