zxc ®   18-Feb-2015 12:34
TRANSAS Navigator Software Products [NSP30]
Year: 2011
Version: 1.03.03
Developer: TRANSAS
Platform: PC (Windows)
Compatibility with Windows7:unknown
System requirements: Windows 98 / 2000 / XP
Crack: included
Description:
This CD contains the following software:
-- TRANSAS Navigator
version 1.03.03
build 5456
with Chart Catalogue ver.4.05.065
-- Tsunamis'99
version 3.02.6
build 685
-- Chart Catalogue (version for Tsunamis'99)
version 4.05.055
-- Installation Guide
-- TRANSAS Navigator help:
ENGLISH - (<CD-ROM>:\HELP\ENG\NS3000.chm)
FRENCH - (<CD-ROM>:\HELP\FRA\NS3000.chm)
PORTUGUESE - (<CD-ROM>:\HELP\POR\NS3000.chm)
-- Transas Dongle checker program (<CD-ROM>:\TDCHK\TDCHK.exe)
version 1.05.018
-- Transas troubleshooting aid (<CD-ROM>:\First_Aid\Setup.exe)
version 1.2.56
Attention!
For the users of "TRANSAS Navigator" program:
Before the installation of chart permits and installation of charts themselves
from the any CD with TRANSAS charts ("World Chart Folio"),
it is necessary first to INSTALL "TRANSAS Navigator" software from:
- WWW.TRANSASNAVIGATOR.COM
- this disk (<CD-ROM>:\NAVIGATOR\Setup.exe);
- "TRANSAS Navigator Software Products, Issue NSP27, Year 2007" disk or later,
For the users of "Tsunamis'99" program:
starting from the any CD with TRANSAS charts ("World Chart Folio"),
it is necessary first to INSTALL/UPGRADE "Tsunamis'99" and INSTALL
"Chart Catalogue" (version for Tsunamis'99) software from:
- this disk (<CD-ROM>:\TSUNAMIS\Setup.exe);
- this disk (<CD-ROM>:\CATALOGUE99\Setup.exe);
A) Please, follow the InstallShield's instructions carefully
during the installation.
Where USB dongles are used with the TRANSAS Navigator
program, the following principal rules should be observed:
1. The USB dongle should not be connected until after the
software installation and computer restart !!!
It should be connected only when the computer's
operational system is running normally.
2. Check the correctness of the USB dongle installation.
Dongle must be insert against stop in USB port, at that
on the dongle must glow a green colour indicator,
showing the correct USB dongle installation.
B) Starting from CD WF 16, TRANSAS Navigator Standard and
TRANSAS Navigator Pro require the availability of both,
dongle and "Standard" or "Pro" permit, to operate.
C) This disk contains electronic HELP in the following languages:
ENGLISH
FRENCH
PORTUGUESE
The default language chosen for the use in the
TRANSAS Navigator is English.
To use another language, used the following procedure:
- Copy "NS3000.chm" HELP file from the necessary directory:
FRENCH - <CD-ROM>:\HELP\FRA\NS3000.CHM
PORTUGUESE - <CD-ROM>:\HELP\POR\NS3000.CHM
and place this file in the root directory of the installed
TRANSAS Navigator system (C:\Transas\Navigator\Help - by default)
on your computer.
- Run TRANSAS Navigator and check if the selected HELP file is
available in the system by pressing HELP button.
* You will later be able to re-connect the English version of
the HELP file by using "NS3000.chm" file from
(<CD-ROM>:\HELP\ENG\NS3000.CHM) in much the same way.
D) The disk contains some version of dongle drivers:
SENTINEL v.5.39 - (<CD-ROM>:\SENTINEL\SENTINEL 5.39\);
SENTINEL v.5.41 - (<CD-ROM>:\SENTINEL\SENTINEL 5.41\);
SENTINEL v.7.4.0 - (<CD-ROM>:\SENTINEL\SENTINEL 7.4.0\);
SENTINEL v.7.6.1 - (<CD-ROM>:\SENTINEL\SENTINEL 7.6.1\);
How To Crack
Read "CRACK\Help.txt"
Instructions:
insert CD to computer, then setup will automatically start (or run SETUP.EXE), choose "Setup Tsunamis Navigator", follow the installation steps.
At the end of installation process, setup will ask you reboot. DO NOT!!!
choose "No, I will restart my computer later".
now crack process:
- Go to tsuncrk folder, and then in the folder drivers run Instdrv.exe and choose "install driver" and then "exit"
- reboot computer.
- after reboot and login - setup will continue the installation on the backround (you will not see anything).
- run installed tsunamis navigator configuration and register with the following permit codes:
Permit codes
Code:
Serial Number: 0001-000000-0019-002108
Tsunamis Navigator Pro Permit Code: 15175-90909-19151-71209
Tide and Current Permit Code: 01226-55034-69151-74048
folio ZR00 issue WCF 15 Permit Code: 13719-63074-26754-24991
AIS Interface Permit Code: NOT AVAILABLE
Important:
- You will need to copy this ISO file on a DVD (the ISO file is 740mb & it will probably not fit on a CD)
- The crack applies only in 32bit operating systems (tested on Windows XP 32bit and Windows 7 32bit)
- To install the software, you must have a parallel port on your pc,....if not you must install a virtual printer port (ECP)
Transas Navigator v1.03.03 build 5456 + World Chart Folio 15 + Permit codes.iso
Download [15 KB]
kalamalaki   02-Apr-2015 23:44
Anyone has newer charges than WF15 ? and the unlock code for the AIS module
thanks
M
Dolboegik   28-May-2015 15:05
Но ведь кряк только для Tsunamis... а сам Transas Navigator запускается в дэмо режиме... подскажите как крякнуть Transas Navigator?
red1978   02-Jun-2015 11:00
Я ТАК И НЕ ПОНЯЛ КАК АКТИВИРОВАТЬ УСТАНОВИЛ КРЯК И ВСЕ РАВНО ДЕМО РЕЖИМ ПИШЕТ ЧТО НЕ ОБНАРУЖЕНЫ ДОНГЛ ДРАЙВЕРА
НАПИШИТЕ ПОДРОБНЕЕ КАК ПРАВИЛЬНО АКТИВИРОВАТЬ НА НОРМАЛЬНОМ ЧЕЛОВЕЧЕСКОМ ЯЗЫКЕ
red1978   02-Jun-2015 17:01
при активации неправильный серийник несколько раз пробовал активировать но безуспешно
помогите решить проблему
Christian05   23-Jun-2016 14:38
21299Перезалито в образе
Can I use this as a simulator on my laptop for me to study the ECDIS?
By the way, I am a BSMT student
Snowmechanic   14-Sep-2016 11:39
I'm just chasing the crack for tsunamis 99 I already have the program installed from the cd but no dongle can anyone help me
sweetydady   19-Apr-2017 08:56
скачал, в папке ничего кроме программы (ни кряка ни чего)
Arcan   19-Apr-2017 09:48
30291скачал, в папке ничего кроме программы (ни кряка ни чего)
Вам, видимо, сначала надо внимательно прочесть ЭТО
zxc ®   19-Apr-2017 10:39
Вы скачали образ диска, вам нужно его смонтировать с помощью Daemon Tools. Внутри будет папка Crack. Работоспособность лекарства не проверял
sweetydady   19-Apr-2017 15:30
30294
как скачивать торрентом я отлично знаю. я ведь скачал, и у меня кроме проги в скачаном файле ничего нет
sweetydady   19-Apr-2017 15:32
30297Вы скачали образ диска, вам нужно его смонтировать с помощью Daemon Tools. Внутри будет папка Crack. Работоспособность лекарства не проверял
детально: я скачал файл TSN.EXE (не iso), то есть это не образ. при открытии его он просит его разархивировать, то есть это архив. разархивировав обнаруживаю что ничего там кроме как программы нет
sweetydady   19-Apr-2017 15:34
30311
повторно поставил на закачку, вроде бы теперь исо качает...ничего не пойму.
sweetydady   19-Apr-2017 15:57
в общем не получается крякнуть.. на виндовс 7. на этапе запуска instldrv.exe просит заменить каккие то файлы - разрешаю, и в итоге потом ошибка 0x4fb "служба уже стартовала и необходимо запустить ее", в общем драйвер не устанавливается..
HMC ECDIS v.5.1 [2014]
Diagnos & Programmer 3 v.2.46.1 - Scania [2021]
TELchart v.3.5.32 [2011]
OPYC - Old Pelican Yacht Club v.3.6.1 - Omar Reis [2022]
MaxSea v12.6.4.1 + CM93v3 Nov-2019 charts (Windows 10 VirtualBox) - MaxSea [2019]
Engine Room Simulator (VLCC A Simulator) - Dalian Haizhi Technology Co. Ltd. [2017]
EIVA Workflow Manager v.4.6.0.4 - EIVA [2022]
VR Tool v.4.1.1 - Omar Reis [2022]
The time now is: Today 15:01
