keyur ®   12-May-2023 15:25
ASME Boiler and Pressure Vessel Code Section IV - Rules for Construction of Heating Boilers
Year: 2007
Author: ASME
Genre: Technical book
Publisher: The American Society of Mechanical Engineers
Edition: 2007
Pages count: 299
Description: The ASME Boiler & Pressure Vessel Code (BPVC) is an American Society of Mechanical Engineers (ASME) standard that regulates the design and construction of boilers and pressure vessels. The document is written and maintained by volunteers chosen for their technical expertise. The ASME works as an accreditation body and entitles independent third parties (such as verification, testing and certification agencies) to inspect and ensure compliance to the BPVC.
This Section provides requirements for design, fabrication, installation and inspection of steam heating, hot water heating, hot water supply boilers, and potable water heaters intended for low pressure service that are directly fired by oil, gas, electricity, coal or other solid or liquid fuels. It contains appendices which cover approval of new material, methods of checking safety valve and safety relief valve capacity, examples of methods of checking safety valve and safety relief valve capacity, examples of methods of calculation and computation, definitions relating to boiler design and welding, and quality control systems. Rules pertaining to use of the H, HV, and HLW ASME Product Certification Marks are also included.
Careful application of this Section will help users to comply with applicable regulations within their jurisdictions, while achieving the operational, cost and safety benefits to be gained from the many industry best-practices detailed within these volumes.
Pressure Vessels: ASME Code Simplified - J. Phillip Ellenberger [2004, PDF]
Guidebook for the design of ASME Section VIII Pressure Vessel (2010) - James R. Farr Maan H. Jawad…
Boiler Control Systems Engineering - G. F. (Jerry) Gilman [2005, PDF]
Boiler Operator’s Guide - Ray Wohlfarth, Anthony L. Kohan [2021, PDF]
Power Boilers: A Guide to the Section I of the ASME Boiler and Pressure Vessel Code - John R.…
Guide For Materials and Welding for Stainless Steels, 2019 - ABS [2018, PDF]
China ship building quality standard [2005, PDF]
Electrical installation guide According to IEC international standards - Schneider Electric S.A.…
Marine Structural Design Calculations - Mohamed A. El-Reedy [2015, PDF]
The time now is: Today 15:57
