moses11m ®   06-Dec-2019 20:25
Guidebook for the design of ASME Section VIII Pressure Vessel (2010)
Year: 2010
Author: James R. Farr Maan H. Jawad
Publisher: ASME
Edition: second
ISBN: 9780791859520
Pages count: 344
Description: Whether you are a beginning design engineer or an experienced engineering manager developing a mechanical integrity program, this updated volume gives you a thorough examination and review of the requirements applicable to the design, materials selection, fabrication, inspection, and testing of pressure vessels and their components. ""Guidebook for Design of ASME Section VIII Pressure Vessels"" provides you with a review of the background issues, reference materials, technology, and techniques necessary for the safe, reliable, cost-efficient function of pressure vessels in the petrochemical, paper, power, and other industries. Solved examples throughout the volume illustrate the application of various equations given in ""Section VIII"".
guidebook-for-the-design-of-asme-section-viii-pressure-vessel-(moses11m)
Valve Selection In Piping Systems For Oil And Gas [2024, MP4]
Power Boilers: A Guide to the Section I of the ASME Boiler and Pressure Vessel Code - John R.…
Steam boilers : Principles, Operations, Design & Control [2024, MP4]
Guide For Materials and Welding for Stainless Steels, 2019 - ABS [2018, PDF]
Handbook of Bolts and Bolted Joints - Sayed A. Nassar [2025, PDF]
Boiler Operator’s Guide - Ray Wohlfarth, Anthony L. Kohan [2021, PDF]
Loop File, LHS, Punch Point, Pressure Test, Box Up, Handover [2024, MP4]
Applied Welding Engineering. Processes, Codes, and Standards - Ramesh Singh [2016, PDF]
Pressure Vessels: ASME Code Simplified - J. Phillip Ellenberger [2004, PDF]
The time now is: Today 15:16
