sun2842451 ®   02-Feb-2018 08:54
China ship building quality standard
Year: 2005
Author: China's state administration of quality supervision, inspection and quarantine and the national standardization administration
Pages count: 108
Description: NOTES
There documents are shipbuilding quality standard implemented by our yard presently. They consist of two parts like QUALITY CONTROL THROUGH PRODUCTION and CONSTRUCTION ACCURACY Taken as a main basis for the shipbuilding in our yard, this construction accuracy is made according to the shipbuilding quality standard in advanced shipbuilding nations, international conventions as well as rules and regulations of some well-known classification societies. For this purpose, we require:
1. detailed workmanship and drawings, if no other specific restriction, comply with the respective requirements stated in this STANDARD. In case of difference, this STANDARD shall govern all.
2. should there be some items in the newbuilding contract or technical specification of higher requirement than this STANDARD, these items should be regarded as an exception and performed according to specific requirement otherwise announced.
CONTENTS
PART 1 QUALITY CONTROL THROUGH PRODUCTION
1 STEEL MATERIAL AND PROCESSING………………………………………6
1.1 Steel material…………………………………………………………………… ..6
1.2 Steel processing………………………………………………………… ………...6
2 FIXING AND ASSEMBLING……………………………………………………7
2.1 Fixing and assembling of parts and members………………………………….…7
2.2 Block assembling…………………………………………………………………7
3 WELDING……………………………………………………………………….8
3.1 Preparation before welding……………………………………………….………8
3.2 Welding process………………………………………………………………….8
3.3 Welding inspection……………………………………………………………….8
3.4 Key points of quality control……………………………………………………..9
4 TIGHTNESS TEST………………………………………………………………..9
5 FABRICATION,FIXING,TIGHTNESS TESTING AND FLUSHING OF PIPES………………………………………………………………………………10
5.1 Fabrication of pipes………………………………………………………..…….10
5.2 Fixing of pipes and fittings…………………………………………………… .11
5.3 Tightness testing of piping system……………………………………………....12
5.4 Flushing of pipes…………………………………………………………………12
6 PAINTING………………………………………………………………...………13
6.1 Pre-treatment of steel surface……………………………………………………13
6.2 Shop primertouch-up………………………………………………………….....13
6.3 Secondary derusting and surface cleaning…………………………………...….13
6.4 Painting work…………………………………………………………………..13
7 HULL OUTFITTING……………………………………………………………13
7.1 Pre-outfitting of ship equipment…………………………………………………13
7.2 Approval of ship equipment……………………………………………………...13
7.3 Installation of ship equipment……………………………………………………14
7.4 Key points of quality control…………………………………………………….14
8 MACHINERY INSTALLATION……………………………………………….15
8.1 Shafting and propeller…………………………………………………………..15
8.2 Main engine and accessories……………………………………………………17
8.3 Auxiliary machinery…………………………………………………………….18
8.4 Boiler……………………………………………………………………………19
9 ELECTRIC INSTALLATION………………………………………………….19
9.1 Electric fittings………………………………………………………………….19
9.2 Cable laying……………………………………………………………………..20
9.3 Installation and earthing of electric equipment…………………………………20
9.4 Connection and earthing of metal covering of cables…………………………..21
10 AUTOMATIC CONTROL AND REMOTE CONTROL,TELEMETRY EQUIPMENT AND THEIR TESTING……………………………………….…21
10.1 Sensors………………………………………………………………………...21
10.2 Automatic control and remote control…………………………………….…..22
10.3 Monitoring and alarming………………………………………………….…..22
10.4 Test of unattended engine room…………………………………………….…23
11 MOORING TEST AND SEA TRIAL………………………………………..23
11.1 Mooring test and sea trial for hull part………………………………………..23
11.2 Mooring test and sea trial for machinery part…………………………….…...24
11.3 Mooring test and sea trial for electric part………………………………….…25
12 COMPLETION AND DELIVERY…………………………………………..25
12.1 Delivery of cabin equipment, spares and supplies……………………………25
12.2 Inspection of marking and operation instructions……………………………...25
12.3 As-built drawings and ship delivery documents………………………………26
12.4 Certificates to be handed over…………………………………………………26
PART 2 PLANS FOR APPROVAL AND INSPECITIONS AND TESTS FOR ACCEPTANCE
1 PLANS FOR APPROVAL……………………………………………………..27
1.1 General ……………………………………………………………………….27
1.2 Plans and documents to be submitted for review and approval………………27
2 INSPECTIONS AND TESTS FOR ACCEPTANCE……………………..32
2.1 General……………………………………………………………………….32
2.2 Items of inspection and tests………………………………………………….33
CSQS(China ship building quality standard - China's state administration of quality supervision, inspection and quarantine and ) - English version.pdf
Download [1 KB]
Arcan   02-Feb-2018 10:44
sun2842451,
Everything Ok except only one note: in the name of file ( and torrent file also) should not be any letters other then latin or russian.
Therefore I put status "not formalized until" to give you a possibility edit your release.
Please do following:
1. Rename your pdf file with using only latin or russian letters.
2. Create torrent file.
3. Replace torrent file in your release here and submit it.
4. Download your torrent file from site and add it to your torrent client software.
Arcan   02-Feb-2018 12:40
sun2842451, Now OK.
You need only to download back your torrent file and add it to your torrent client, otherwise nobody can download your release.
And keep your torrent client running, until your release will be downloaded at least 1-2 peers.
Good luck!
Arcan   03-Feb-2018 17:32
Hey, sun2842451, are you alive? Follow instructions made in the previous post, please. Otherwise nobody can download your torrent.
Arcan   05-Feb-2018 08:52
sun2842451,
Seeder not seen: Never
Something wrong.
Delete ( torrent only) from your Utorrent and add once again those, which you download from site.
Arcan   05-Feb-2018 11:50
Here is plenty seeders already but not you...
Finally it works.
paparrejo   17-Nov-2021 10:02
Could you teach how could i can post any book to raise my rank.
so i can get some other book too.
many thank.
paparrejo   17-Nov-2021 14:42
skipper3362, thank you, I already try post something.
pls help me raise my reputation...many thank
CB/T 4000-2005 China Shipbuilding Quality Standard - Commision of science technology and industry fo...
Standard Ship Test and Inspection Plan, Procedures and Database (NSRP) [1999, PDF] - National Steel ...
Common Structural Rules for Bulk Carriers and Oil Tankers - IACS [2025, PDF]
Equivalent standards for the construction of Artic Class Ship TP 12660 - N/A [1995, PDF]
MEO CLASS 1 Notes - A.K.Sharma [2017, PDF]
Classification societies – what, why and how?, Updated 2015 - IACS [2011, PDF]
Rules and Guidelines of China Classification Socirty (CCS) - CCS [2018, PDF]
Technical Guidelines - Marine & Offshore Insulation - ROCKWOOL Technical Insulation [2016, PDF]
International Code For The Construction and Equipment of Ships Carrying Liquefied Gases in Bulk (IGC...
The elements of wood ship construction - Curtis W.H. [1919, PDF]
The time now is: Today 03:00
