virtual ®   02-Dec-2018 18:32
Electrical installation guide According to IEC international standards
Year: 2016
Author: Schneider Electric S.A.
ISBN: 978.2.9531643.3.6
Pages count: 580
Description: This guide has been written for electrical Engineers who have to design,
select electrical equipment, install these equipment and, inspect or
maintain low-voltage electrical installations in compliance with international
Standards of the International Electrotechnical Commission (IEC).
“Which technical solution will guarantee that all relevant safety rules are
met?” This question has been a permanent guideline for the elaboration of
this document.
An international Standard such as the IEC 60364 series “Low voltage
Electrical Installations” specifies extensively the rules to comply with to
ensure safety and correct operational functioning of all types of electrical
installations. As the Standard must be extensive, and has to be applicable
to all types of equipment and the technical solutions in use worldwide, the
text of the IEC rules is complex, and not presented in a ready-to-use order.
The Standard cannot therefore be considered as a working handbook, but
only as a reference document.
The aim of the present guide is to provide a clear, practical and stepby-
step explanation for the complete study of an electrical installation,
according to IEC 60364 series and other relevant IEC Standards. The first
chapter (A) presents the methodology to be used, and refers to all chapters
of the guide according to the different steps of the study.
We all hope that you, the reader, will find this handbook genuinely helpful.
SEGuide2016.pdf
IEC 60092 - Electrical Installations in Ships - IEC [2016, PDF]
Handbook to IEEE Standard 45: A Guide to Electrical Installations on Shipboard - Mohammed M. Islam [...
ASME Boiler and Pressure Vessel Code Section IV - Rules for Construction of Heating Boilers - ASME [...
ASME Boiler and Pressure Vessel Code Section VI - Recommended Rules for the Care and Operation of He...
Code of Practice 4, Industrial Gas Cylinder Manifolds and Gas Distribution Pipework (excluding Acety...
Icon DP2 Dynamic Positioning System Class 2 User Manual - Rolls-Royce [2013, PDF]
BS EN 1473 -2007 - Installation and equipment for liquefied natural gas — Design of onshore installa...
IEEE 45 Standard_Recommended Practice for Electrical Installations on Shipboard-2002 - IEEE [2002, P...
TP 127E, Ships Electrical Standards, Revision 03 - Transport Canada [2018, PDF]
Maritime Electrical Installations And Diesel Electric Propulsion - Alf Kare Adnanes [2003, PDF]
The time now is: Today 03:30
