Anand Kumar ®   07-Oct-2020 09:10
Pressure Vessels: ASME Code Simplified
Year: 2004
Author: J. Phillip Ellenberger
Genre: Technical book
Publisher: McGraw-Hill Education
Edition: 8
ISBN: 978-0071436731
Pages count: 320
Description: Pressure vessels are found everywhere -- from basement boilers to gasoline tankers -- and their usefulness is surpassed only by the hazardous consequences if they are not properly constructed and maintained. This essential reference guides mechanical engineers and technicians through the maze of the continually updated International Boiler and Pressure Vessel Codes that govern safety, design, fabrication, and inspection.
Additional info
Editorial Reviews
From the Publisher
J. Phillip Ellenberger, P.E., is Vice President of Engineering at WFI International, Inc., Houston, Texas, a design and manufacturing firm specializing in machined branch connections; and a life member of ASME, for which he serves on several codes and standards committees. Mr. Ellenberger is active with the B16 F & C subcommittees, the B31.3 design task group, and the B31 mechanical design and fabrication committee. He is also the MSS Chairman of the Coordinating Committee and Committee 113, and is member of WG 10 SC67. He has taught piping stress analysis at the University of Houston, and numerous professional seminars on B31.3 and related topics. --This text refers to an alternate kindle_edition edition.
About the Author
From the Inside Flap
"A useful addition to any ASME Code shop...This volume does what the title promises...well-written and eminently readable." -- Welding Design and Fabrication [on previous edition]
Get Up to Speed with the ASME Code
Revised and updated, this classic engineering tool simplifies the tasks of understanding and applying the complex ASME Code for fabricating, purchasing, testing, and inspecting pressure vessels.
Clearly explaining changes in B31.3, this Eighth Edition makes it easier to achieve Code compliance on any pressure-vessel-related project, to obtain ASME Code certification, and to meet performance goals in the most cost-effective way possible. Pressure Vessels explains the value of Code standards, shows you how the Code applies to each component, and clarifies requirements that may be confusing. This valuable text also features tables for caluclating allowable internal pressures. You'll learn how to comply with ASME standards for:
* Safety procedures for design and maintenance
* Inspection and quality control
* Welding
* Nondestructive testing
* Fabrication and installation
* Pressure vessels in nuclear power plants
Filled with helpful solutions to typical problems, the new edition of this handy working tool will give you the expertise you need to deal with all the changes in requirements for pressure vessels. --This text refers to an alternate kindle_edition edition.
From the Back Cover
Publisher's Note: Products purchased from Third Party sellers are not guaranteed by the publisher for quality, authenticity, or access to any online entitlements included with the product.
* Welding
70F3F179894B4CAF1F8AC64082B5E689E0572919
Download [1 KB]
ASME Boiler and Pressure Vessel Code Section IV - Rules for Construction of Heating Boilers - ASME [...
ASME Boiler and Pressure Vessel Code Section VI - Recommended Rules for the Care and Operation of He...
Power Boilers: A Guide to the Section I of the ASME Boiler and Pressure Vessel Code - John R. MacKay...
Guidebook for the design of ASME Section VIII Pressure Vessel (2010) - James R. Farr Maan H. Jawad [...
Standard Handbook of Engineering Calculations - Tyler G. Hicks, Tyler Hicks [2004, PDF]
Piping Systems Manual - Brian Silowash [2010, PDF]
Pressure Vessels Field Manual - Common Operating Problems and Practical Solutions - Maurice Stewart,...
Boatbuilding Manual - Robert M. Steward with Carl Cramer [2010, PDF/EPUB]
The essential knot book - Jarman C. [2014, PDF/EPUB]
Safe Operation and Maintenance of Dry Dock Facilities - Paul_A._Harren [2010, PDF]
The time now is: Today 19:05
