pierdolphin1950 ®   23-Oct-2022 12:15
ABS - Inspection Grading Criteria for the ABS Hull Inspection and Maintenance Program (HIMP)
Year: 2009
Author: ABS
Pages count: 64
Description: This manual and the inspection regime described herein are for
use solely within the ABS Hull Inspection Maintenance Program
(HIMP). The grading and actions to be taken on those gradings
are of a suggested nature only. They are not to be construed as
representative of ABS class criteria or the actions taken by class
upon discovery of the various types of defects noted in this hull
inspection grading manual
The six inspection criteria cover:
• Coating condition
• Presence of general corrosion
• Presence of pitting or grooving or other localized linear corrosion
• Presence of deformation
• Presence of fractures
• Compartment or space cleanliness (housekeeping and fabric maintenance such as anode replace-
ment, etc.)
ABS - Inspection Grading Criteria for the ABS Hull Inspection and Maintenance Program (HIMP).pdf
ClaireVoyant   16-Aug-2023 07:21
There's a code with small letters in the last page of both this version and the 2017 version that goes like MM/YY. In this one it's 01/09, so this release is from 2009
5
Inspection Grading for Hull Inspection Maintenace Program (HIMP) - American Bureau of Shipping [2017...
Guide for Hull Inspection and Maintenance Program - American Bureau of Shipping [2016, PDF]
Are your hatch covers weathertight? - Per Haveland [2022, PDF]
Guidance Manual for Tanker Structures, 2024 Consolidated Edition - Witherby / Tanker Structure Co-op...
Shipbuilding and Repair Quality Standard (Rec.47) Corrected - IACS [2025, PDF]
Loss Prevention Bulletin, Cargo Hold Cleaning - West of England P&I [2017, PDF]
Guide for Coating Maintenance & Repairs for Ballast Tanks on Oil Tankers - IACS [2015, PDF]
Safe Operation and Maintenance of Dry Dock Facilities - Paul_A._Harren [2010, PDF]
The time now is: Today 11:25
