paolina_3 ®   17-Mar-2021 18:08
Inspection Grading for Hull Inspection Maintenace Program (HIMP)
Year: 2017
Author: American Bureau of Shipping
Publisher: American Bureau of Shipping
Pages count: 64
Description: American Bureau of Shipping is the Class leader in the tanker industry, with an extensive global experience in all sizes of tankers, surveyors and engineers around the world. ABS is looked upon as a trusted service provider not only for classification services, but also for leading technology and research geared toward improving vessel performance. This hull inspection grading manual details a program for hull structural inspections, in order to comply with the ABS HIMP Guide. It outlines the work scope and reporting requirements for the vessel, and contains the information to be collected by the vessel crew or superintendents. The hull conditions are to be assessed and rated in accordance with a set of six general condition criteria coupled with selected targeted inspections of identified critical areas for this design series. The manual draws on the information available from IMO, IACS and ABS publications. It is intended to be utilized in accordance with the Hull Inspection and Maintenance Program (HIMP), and it may also be used to assist with maintenance and repairs of IMO PSPC coatings for dedicated seawater ballast tanks and crude oil tanks per IMO Resolutions MSC.215(82) and MSC.288(87).
Inspection Grading for Hull Inspection Maintenace Program.pdf
Guide for Hull Inspection and Maintenance Program - American Bureau of Shipping [2016, PDF]
Shuttle Tanker Advisory - American Bureau of Shipping [2019, PDF]
ABS Shuttle Tanker Advisory - October 2020 - ABS [2020, PDF]
Guidance Notes on Maintenance and Repair of Protective Coatings - ABS [2017, PDF]
Guide for Coating Maintenance & Repairs for Ballast Tanks on Oil Tankers - IACS [2015, PDF]
ABS - Inspection Grading Criteria for the ABS Hull Inspection and Maintenance Program (HIMP) - ABS…
Coating Maintenance– Guidelines for Coating Maintenance & Repairs for Ballast Tanks and Combined…
Guidance Manual for Tanker Structures, 2024 Consolidated Edition - Witherby / Tanker Structure…
JOTUN-Onboard Maintenance Manual - JOTUN [2015]
Design and Operations of Double Hull Tankers - RINA [2004, PDF]
The time now is: Today 16:00
