jeroenimo ®   02-Dec-2019 14:49
VirtualBox windows 10 with MaxSea v12.6.4.1 and Nov-2019 CM93v3 charts installed
Year: 2019
Developer: MaxSea
System Requirements: reasonable fast host computer(Win/Linux/MacOS) 64bit version with preferably more then 8GB RAM.
Crack: Included
Description: This is a Win10 virtualbox image with maxsea installed, hacked/activated and CM93v3 November 2019 charts installed, you will need to do the settings for connecting GPS/AIS etc. etc.
It's not 100% "easy does it" and needs a little tweaking sometimes to get it to work as most of this kind of stuff is. If for some reason the charts do not show up, you can repeat the installation manual instructions inside, also the maxsea manual is very helpfull!
I've always managed to get it working again.
Login for win10 maxsea:maxsea
Prerequisites:
-Reasonably fast computer (recent Intel i5/i7 or similar with preferably SSD storage) with minimal 8GB Ram installed (Windows/Mac/Linux)
-Oracle Virtualbox software install, and make sure you install the expansionpack as well (needed for USB connections to the VM. if you want to connect a GPS or similar)
Make sure you have the virtualbox software from oracle installed, this is a free software system to enable virtual machine on a Linux/Mac/Windows host machine.
https://www.virtualbox.org/wiki/Downloads
If you run in trouble make sure you have RAM and amount of CPU's set to your system properly in the VM settings.
The installation media for MaxSea (from this tracker) is included too, you can install newer versions of CM93v3 charts in the VM.
Please be very sure that you read the instructions inside the diskimage which is on the desktop, and before you start make sure you make a snapshot of the VM, making it really easy to revert back if you somehow f*cked up ;-)
The system will complain about expired licences, but the charts will continue working, not an issue, just click OK (See screenhot)
Have fun, and please use official paper charts or ECDIS systems for ships navigation! (although this has saved my bacon multiple times ;-))
maxsea-virtualbox.zip  GOLDEN RELEASE!
Download [178 KB]
jeroenimo ®   07-Dec-2019 16:31
@andrey11
I'm sorry if the system fails for you!
My russian is not that good, but on the desktop of the VM there is an .iso file with the MaxSea installation and manual.
Basically you have to re-run the chart installation.
Read the instructions in the PDF file and start at point 7
The CM93Ed3 charts are in the C:\
Good luck!
P.S. if you want to update the CM93Ed3 the same procedure applies!
jeroenimo ®   28-Dec-2019 13:52
roshdi3, No you need virtualbox, or maybe VMware might work too, I haven't tried because I run a linux machine, and my package manager has the free option virtualbox.
Lonely Sail   02-Feb-2020 09:44
I installed the program. everything went Ok and Maxsea started.
But no C-Map charts opens. I can see just vector skeleton and this is all.
I tried to reinstall C-Map charts but it's the same.
jeroenimo ®   02-Feb-2020 14:36
If for some reason the charts do not open, please reinitialize the setup from the iso file readme on the desktop.
And then you might have to reopen the C93 charts in the settings.
It works for me every time!
5
Lonely Sail   03-Feb-2020 13:13
Yahoooo!!! ))) Ураааа!!! ))))
Done!! ))))
It is working now.
Thank you very much!!! )))
Just only one question.
I have a warning when start Maxsea
"Your licenses for the following zone will expire in two month"
Is it ok?
jeroenimo ®   03-Feb-2020 15:49
Lonely Sail, Please read my description/comments on the torrent again ;-)
Brubeck   09-Mar-2020 13:59
jeroenimo,
Good morning jeroenimo
Is it a professional version, please?
Can I use USB Pilot Plug to get the AIS signals?
TIA
Xinutop: Dedicated Marine OS v.VDI version X86 2.3 - Frank Baudet [2019]
VHD-Operation system win7 x86 ru and TRANSAS NS3000/NP4000 v.2.0 - Transas [2015]
The VLCC-A DMSCTS 3D+2D+M (E.R.S Simulator) v.2024 - DMSCTS DALIAN MARITIME UNIVERSITY [2026]
dKart Navigator 9000 SP2 v3.41.4 build 916 + cm93 v3 WF870 + Installation tutorial for win 10 (Full ...
Navi-sailor 3000. VirtualBox Workstation with Win 10(En) x64 + WF61 Fixed v.4.00.10 [2008]
TELchart v.3.5.32 [2011]
The time now is: Today 22:16
