gillnumil ®   23-Sep-2018 05:09
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG)
Year: 1994
Author: OCIMF
Publisher: Witherby Publishing Group Ltd
Edition: 2nd
ISBN: 1856090663
Pages count: 77
Description: These recommendations are promulgated to introduce conformity in manifold arrangements of Liquefied Natural Gas Carriers (LNG) in order to promote improved efficiency in operation and assist in planning the position of loading and discharging facilities on new jetties.
The specification has been prepared by drawing on the experience of LNG ship operators, berth design specialists, naval architects, ship constructors and equipments manufacturers. It is intended to serve as a guideline to LNG ship owners and builders and to those planning jetty design. It is not implied that existing vessels should be altered.
It is intended that these recommendations apply only to dedicated LNG carriers with midship manifold arrangements. Where vessels are designed for one or more grades of LPG as well as LNG, or where cargo transfer manifolds are in locations other than within the midships area, special arrangements will be necessary which are outside the scope of this document.
OCIMF Recommendations for manifolds for LNG carriers.pdf
Download [911 B]
Recommendations for Manifolds of Refrigerated Liquefied Gas Carriers for Cargoes from 0°C to minus…
Recommendations For Liquefied Gas Carriers Manifolds - SIGTTO [2018, PDF]
Manifolds Recommendations for Liquefied Gas Carrier - Witherby [2011, PDF]
SIGTTO - OCIMF - Recommendations For Liquefied Gas Carriers Manifolds - ed 2018 - SIGTTO - OCIMF…
Recommendations for Oil Tanker Manifolds and Associated Equipment - OCIMF [1991, PDF]
LNG Transfer Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2012, PDF]
LNG Marine Loading Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2107,…
Recommendations for Designing Cargo Control Rooms - SIGTTO [2020, PDF]
ESD Arrangements & linked ship shore systems for Liquefied Gas Carriers - SIGTTO [2009, PDF]
The time now is: Today 15:02
