mmh ®   26-Apr-2019 09:20
Recommendations For Liquefied Gas Carriers Manifolds
Year: 2018
Author: SIGTTO
Genre: Reference book
Publisher: Witherby Publishing Group Ltd
Edition: 2nd
ISBN: 978-1-85609-769-7
Quality: OCR without errors
Pages count: 47
Description: Introduction
This document provides recommendations on the layout, strength and fittings for gas carrier manifolds. This
version is an update to the previous edition of 'Manifold Recommendations for Liquefied Gas Carriers (2011Y).
Scope
These recommendations are for liquefied petroleum gas (LPG) carriers and liquefied natural gas (LNG) carriers.
For the purposes of this document, the term LPG carrier refers to liquefied gas cargoes carried between the
temperature range of 0°C to -104°C
These recommendations do not apply to existing ships, and there is no suggestion that existing ships should be
altered.
It is recognised that some new gas carrier designs may not be able to conform to all of the recommendations
in this document, however, this document is intended to serve as a starting point with a view to minimising
differences as much as possible
1. Introduction.............................................................................................................................................. 1
1.1 Scope...................................................................................................................................................... 3
1.2 Size Categories ..................................................................................................................................... 4
2. Manifold Position...................................................................................................................................... 5
2.1 Manifold - LPG ........................................................................................................................................ 7
2.2 Manifold - LNG ..................................................................................................................................... 12
3. Protection from Cargo Spill ..................................................................................................................... 17
3.1 Deck Protection …………………………………………................................................................................... 19
3.2 Coaming Requirements ....................................................................................................................... 20
3.3 Drip Trays ..............................................................................................................................................20
3.4 Gratings ................................................................................................................................................ 20
3.5 Drainage - LPG...................................................................................................................................... 20
3.6 Drainage - LNG..................................................................................................................................... 20
3.7 Water Curtains for LNG Carriers .......................................................................................................... 21
4. Manifold Design ……......................................................…………………………............................................ 23
4.l Carbon Steel Manifold ........................................................................................................................... 25
4.2 Stainless Steel Manifold....................................................................................................................... 27
4.3 Assumptions used for Load Calculations ........................................................................................... 28
5. Manifold Specification and Fittings ........................................................................................................ 31
5.1 Manifold Flanges.................................................................................................................................... 33
5.2 Presentation Flanges ............................................................................................................................. 34
5.3 Marking of Manifolds ............................................................................................................................. 34
5.4 Distance Pieces....................................................................................................................................... 35
5.5 Reducers and Spool Pieces ...................................................................................................................35
6. Additional Requirements ..........................................……………………………….......................................... 37
6.1 Water and other Connections ............................................................................................................. 39
6.2 Manifold Area Illumination................................................................................................................... 39
6.3 Lifting Equipment and Cargo Hose Support ....................................................................................... 39
6.4 LPG Vessels Involved in Floating Hose Transfers.............................................................................. 39
6.5 Access and Exits from the Manifold Area ........................................................................................... 40
6.6 Access during Cargo Transfer................................................................................................................ 40
7. Bunker Manifolds ..........................•.••..................................................................................................... 41
7.l Number and Arrangement ...................................................................................................................... 43
7.2 Size and Location of Bunker Manifold ............................................................................................... 44
7.3 Reducers and Spool Pieces for Bunkering ................................................................................................. 44
7.4 Strength ................................................................................................................................................. 44
7.5 Oil Spill Containment.............................................................................................................................. 44
7.6 LNG Spill Containment and Protection................................................................................................... 45
7.7 Oil Bunker Hose Saddle ..........................................................................................................................45
7.8 Other Connections..................................................................................................................................45
Annexes................................................................................................................................................................47
Annex 1 - Manifold Strainers ......................................................................................... ..... ... ... .......................49
Annex 2 - Glossary of Terms and Abbreviations ................................................................................................ 50
Annex 3 - References........ ............................................................................................................................... 51
Recommendations For Liquefied Gas Carriers Manifolds ed 2018.pdf
Download [9 KB]
SIGTTO - OCIMF - Recommendations For Liquefied Gas Carriers Manifolds - ed 2018 - SIGTTO - OCIMF [20...
Manifolds Recommendations for Liquefied Gas Carrier - Witherby [2011, PDF]
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG) - OCIMF [1994, P...
The Selection and Testing of Valves for LNG Applications - SIGTTO [2008, PDF]
Recommendations for Manifolds of Refrigerated Liquefied Gas Carriers for Cargoes from 0°C to minus 1...
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
Recommendations for Oil Tanker Manifolds and Associated Equipment - OCIMF [1991, PDF]
Guidance for the Prevention of Rollover in LNG Ships - SIGTTO [2012, PDF]
Liquefied Gas Carriers: Your Personal Safety Guide - SIGTTO [2002, PDF]
The time now is: Today 03:21
