pierdolphin1950 ®   09-Nov-2021 15:53
SIGTTO - OCIMF - Recommendations For Liquefied Gas Carriers Manifolds - ed 2018
Year: 2018
Author: SIGTTO - OCIMF
Pages count: 47
Description: Recommendations For Liquefied Gas Carriers Manifolds - ed 2018 - These recommendations are for liquefied petroleum gas (LPG) carriers and liquefied natural gas (LNG) carriers.
For the purposes of this document, the term LPG carrier refers to liquefied gas cargoes carried between the
temperature range of 0°to -104 °C.
These recommendations do not apply to existing ships, and there is no suggestion that existing ships should be
altered.
It is recognised that some new gas carrier designs may not be able to conform to all of the recommendations
in this document, however, this document is intended to serve as a starting point with a view to minimising
differences as much as possible.
SIGTTO - OCIMF - Recommendations For Liquefied Gas Carriers Manifolds ed 2018.pdf
Download [9 KB]
Manifolds Recommendations for Liquefied Gas Carrier - Witherby [2011, PDF]
Recommendations For Liquefied Gas Carriers Manifolds - SIGTTO [2018, PDF]
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG) - OCIMF [1994, P...
Recommendations for Manifolds of Refrigerated Liquefied Gas Carriers for Cargoes from 0°C to minus 1...
The Selection and Testing of Valves for LNG Applications - SIGTTO [2008, PDF]
Guidance for the Prevention of Rollover in LNG Ships - SIGTTO [2012, PDF]
Bulk Liquified Gas by Sea: The Early Years - Robin Gray [2004, PDF]
The Selection and Testing of Valves for LPG Applications - SIGTTO [2012, PDF]
Code of Practice 4, Industrial Gas Cylinder Manifolds and Gas Distribution Pipework (excluding Acety...
The time now is: Today 15:50
