johnny_tsouk ®   18-Mar-2019 15:00
Recommendations for Liquefied Gas Carrier Manifolds
Year: 2011
Author: Witherby
Pages count: 51
Description: Introduction
This document provides recommendations on the layout, strength and fittings for gas carrier manifolds.
Scope
These recommendations are for liquefied petroleum gas (LPG) carriers and liquefied natural gas (LNG) carriers.
For the purposes of this document, the term LPG carrier refers to liquefied gas cargoes carried between the temperature range of 0°C to -104°C.
These recommendations do not apply to existing ships, and there is no suggestion that existing ships should be altered.
It is recognised that some new gas carrier designs may not be able to conform to all of the recommendations in this document, however, this document is intended to serve as a starting point with a view to minimising differences as much as possible.
1. Introduction
1.1 Scope
1.2 Size Categories
2. Manifold Position
2.1 Manifold – LPG
2.2 Manifold – LNG
3. Protection from Cargo Spill
3.1 Deck Protection
3.2 Coaming Requirements
3.3 Drip Trays
3.4 Gratings
3.5 Drainage – LPG
3.6 Drainage – LNG
3.7 Water Curtains for LNG Carriers
4. Manifold Design
4.1 Carbon Steel Manifold
4.2 Stainless Steel Manifold
4.3 Assumptions used for Load Calculations
5. Manifold Specification and Fittings
5.1 Manifold Flanges
5.2 Presentation Flanges
5.3 Marking of Manifolds
5.4 Distance Pieces
5.5 Reducers and Spool Pieces
6. Additional Requirements
6.1 Water and other Connections
6.2 Manifold Area Illumination
6.3 Lifting Equipment and Cargo Hose Support
6.4 LPG Vessels Involved in Floating Hose Transfers
6.5 Access and Exits from the Manifold Area
6.6 Access during Cargo Transfer
7. Bunker Manifolds
7.1 Number and Arrangement
7.2 Size and Location of Bunker Manifold
7.3 Reducers and Spool Pieces for Bunkering
7.4 Strength
7.5 Oil Spill Containment
7.6 LNG Spill Containment and Protection
7.7 Oil Bunker Hose Saddle
7.8 Other Connections
Annexes
Annex 1 – Manifold Strainers Annex 2 – Glossary of Terms and Abbreviations
Annex 3 – References
Arcan   18-Mar-2019 15:42
johnny_tsouk, Some recommendations:
1/ Name of your release should be the same as the name of the book, i.e. "Manifold Recommendations for Liquefied Gas Carrier" as per this name search is working.
2/ There should be at least three screenshots with readable size of pages from different parts of the book that users can check the quality of scanned pages. Screenshots should not contain first, last and contents pages and page used for poster.
Please arrange these recommendations in your release.
Arcan   29-Apr-2019 13:46
51770HOW CAN I EDIT MY POST?
I hope you already read recommendations given to you.
It's time to adjust your release in accordance with rules of this tracker.
Recommendations For Liquefied Gas Carriers Manifolds - SIGTTO [2018, PDF]
SIGTTO - OCIMF - Recommendations For Liquefied Gas Carriers Manifolds - ed 2018 - SIGTTO - OCIMF…
Recommendations for Oil and Chemical Tanker Manifolds - Oil Companies International Marine Forum…
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG) - OCIMF [1994,…
Guidance for the Prevention of Rollover in LNG Ships - SIGTTO [2012, PDF]
Requirements of Liquefied Carbon Dioxide Carriers - ABS [2024, PDF]
Rules of Korean Register of Shipping - KR [2018, PDF]
LNG Ship to Ship Transfer Risk Assessment - British Petroleum Shipping [2011, PDF]
Recommendations for Manifolds of Refrigerated Liquefied Gas Carriers for Cargoes from 0°C to minus…
  • Topic closed
The time now is: Today 16:55
