gillnumil ®   09-Nov-2018 08:32
LNG Transfer Arms and Manifold Draining, Purging and Disconnection Procedure
Year: 2012
Author: SIGTTO
Genre: Research papers
Publisher: Witherby Publishing Group Ltd
Pages count: 11
Description: SIGTTO has published an advice on LNG transfer arms and manifold draining, purging and disconnection procedure which has been prepared following reports from a number of their members that there appears to be confusion and misunderstanding among some ship and jetty operators over the safe conduct of disconnection procedures following loading and discharge.
The ultimate goal of disconnecting the vessels' cargo handling equipment from the jetty equipment is to eliminate any risk of liquid release and reduce the possibility of vapour release. The purpose of the advice is to promote good industry practice, by all operators reviewing their procedures for draining and purging manifold connections adequately and these procedures being specifically discussed and agreed by both ship and shore prior to the operations commencing.
SIGTTO Purging and Disconnection of LNG Hard Arms.pdf
LNG Marine Loading Arms and Manifold Draining, Purging and Disconnection Procedure - SIGTTO [2107,…
Recommendations for Manifolds for Refrigerated Liquefied Natural Gas Carriers (LNG) - OCIMF [1994,…
Liquefied Petroleum Gas Sampling Procedures - SIGTTO [2010, PDF]
Recommendations for Oil Tanker Manifolds and Associated Equipment - OCIMF [1991, PDF]
ESD Arrangements & linked ship shore systems for Liquefied Gas Carriers - SIGTTO [2009, PDF]
Guidelines for the Alleviation of Excessive Surge Pressure on ESD for Liquefied Gas Transfer…
Recommendations for Oil and Chemical Tanker Manifolds - Oil Companies International Marine Forum…
Thermowells in LNG Carrier Liquid Lines - SIGTTO [2011, PDF]
Guidance for the Prevention of Rollover in LNG Ships - SIGTTO [2012, PDF]
The time now is: Today 16:06
