virtual ®   04-Aug-2018 02:38
Guide to Good industry practices for Bulk LP Gas installations
Year: 2013
Author: World LP Gas Association
Pages count: 73
Description: LP Gas is commonly stored in pressure vessels in various facilities i.e. terminals and depots,
cylinder filling plants, Autogas fuelling stations and customer sites. The capacities of these
facilities can range from 100,000 MT (metric tonnes) for large import terminals to as small
as 0.5 MT for a domestic installation. Whatever the size of an LP Gas installation, any safety
incident whether due to equipment failure or external threats has the potential to cause injury
and/or property damage not only to people working within these facilities but also the
population of the surrounding communities.
It is therefore important to all stakeholders in the industry to manage and reduce the risks
associated with operating an LP Gas facility to As Low As Reasonably Practicable (ALARP).
This can be achieved with suitable design and engineering standards, safe operations, and
comprehensive and rigorous maintenance programmes combined with effective staff
training programmes.
This guide should always be used in conjunction with local standards and regulations.
If the requirements of the local standards or regulations are less than the guide, the latter
should be adopted to ensure a higher level of safety for the LP Gas facility.
The recommendation in this guide applies to pressurised LP Gas facilities covering terminals
and depot, cylinder filling plants, Autogas fuelling sites and industrial, commercial,
agricultural and domestic installations permanently installed and refilled onsite.
This Guide does not cover refrigerated terminals, caverns, salt domes and mobile cylinder
installations.
gbp-guide-to-good-industry-practices-for-bulk-lp-gas-installations.pdf
Safety Flash issue 23/22 - IMCA [2022, PDF]
LPG storage facility and distribution - various [2017, PDF]
Safety Flashes issues 10-17 (May - August) - IMCA [2024, PDF]
KRAL Screw pumps K Series with magnetic coupling / Operating Instructions [2006, PDF]
Guidance Note 34, The Safe Use of Gases in the Steel industry - BCGA [2018, PDF]
Recommendations for the Installation of Cargo Strainers on LNG Carriers, 2nd Edition - SIGTTO [1992,...
Safety Flash issue 03 (February) - IMCA [2024, PDF]
Safety Flash issue 03 (January) - IMCA [2023, PDF]
Safety Flashes issues 25-26 (October - November) - IMCA [2023, PDF]
Code of Practice 18, The Safe Storage, Handling and Use of Special Gases, Revision 3 - BCGA [2014, P...
The time now is: Today 12:57
