virtual ®   22-Dec-2018 12:06
Code of Practice 18, The Safe Storage, Handling and Use of Special Gases, Revision 3
Year: 2014
Author: BCGA
Genre: Convention (rules)
Pages count: 63
Description: This Code of Practice gives technical and safety guidelines and principles for the safe storage
and handling of special gases in transportable containers up to the point where product is
provided at the required pressure and flow at the junction with the user process. Guidelines
on disposal are also given. The Code will assist companies to formulate their own design and
operation policies and practices for the storage, handling and use of special gases. The safe
operation of processes is not included, although many of the principles given in this Code
will apply.
Bulk supply installations, gases in the cryogenic state, gas manufacturing, container filling
and container distribution are not covered by this Code.
BCGA - Code of Practice 18 CP18.pdf
Download [750 B]
Code of Practice 4, Industrial Gas Cylinder Manifolds and Gas Distribution Pipework (excluding…
Code of Practice 7, The Safe Use of Oxy-Fuel Gas Equipment (Individual Portable or Mobile Cylinder…
LPG storage facility and distribution - various [2017, PDF]
Fundamentals of Heat Exchanger Design - Ramesh K. Shah, Dušan P. Sekulic [2003, PDF]
Code of Practice 6, The Safe Distribution of Acetylene in the Pressure Range 0 - 1.5 BAR, Revision…
Guidance Note 34, The Safe Use of Gases in the Steel industry - BCGA [2018, PDF]
NWEA Guidelines for the Safe Management of Offshore Supply and Rig Move Operations - Working Group…
Guidelines for Safety Operation for Ammonia-Fueled Vessels - ClassNK [2025, PDF]
GASRUL: Rules Regulations and General Information for RLPG Terminals, Juaymah, Jazan - Saudi Aramco…
The time now is: Today 16:47
