virtual ®   22-Dec-2018 10:46
Guidance Note 34, The Safe Use of Gases in the Steel industry
Year: 2018
Author: BCGA
Pages count: 29
Description: There are many uses for industrial gases in the steel industry. Oxygen is an important component in the steelmaking process and bulk quantities are either stored or delivered via a pipeline system. A smaller quantity of other bulk gases may also be stored on site, such as argon, nitrogen, natural gas and propane. These gases will be delivered to the point of use via pipelines and/or appropriate pipework. It is probable that there will also be available a range of welding and cutting gases with their associated equipment.
Provided they are stored, handled and used responsibly, knowledgably and correctly the use of gases in the steel industry are a valuable resource and are safe to use.
BCGA GN 34 -BCGA - Guidance Note 34, The Safe Use of Gases.pdf
Download [838 B]
Code of Practice 7, The Safe Use of Oxy-Fuel Gas Equipment (Individual Portable or Mobile Cylinder S...
Guidance Note 11, The Management of Risk when Using Gases in Enclosed Workplaces, Revision 4 - BCGA ...
Code of Practice 6, The Safe Distribution of Acetylene in the Pressure Range 0 - 1.5 BAR, Revision 3...
Code of Practice 4, Industrial Gas Cylinder Manifolds and Gas Distribution Pipework (excluding Acety...
The Basics Of Gas Tungsten Arc Welding [2022, MP4]
The Importance of Cargo Sampling - Japan P&I [2019, PDF]
Code of Practice 18, The Safe Storage, Handling and Use of Special Gases, Revision 3 - BCGA [2014, P...
Code Of Practice 5, The Design and Construction of Manifolds using Acetylene Gas from 1.5 to 25 Bar,...
Guide to Good industry practices for Bulk LP Gas installations - World LP Gas Association [2013, PDF...
Fixed Fire Fighting Systems and Emergency Procedures (For Ship’s Engine Room) - MD MAHBUBUR RAHMAN [...
The time now is: Today 23:01
