virtual ®   23-Sep-2018 09:40
Recommendations for the Installation of Cargo Strainers on LNG Carriers, 2nd Edition
Year: 1992
Author: SIGTTO
Genre: Technical book
Pages count: 14
Description: Until relatively recently cargo strainers have not been fitted or considered necessary on LNG carriers. LNG being essentially a "clean" cargo, filtration has been generally limited to the installation of strainers in the loading lines at the loading terminal principally during the initial commissioning of the plant and build-up period of the project. Avoidance of contamination on the ships has relied on good housekeeping and visual inspection during construction and subsequent maintenance periods. Incidents have occurred, however, where gross solid matter has been discharged into receiving terminal facilities to the extent that terminal operators now require ships to provide some form of cargo straining as a protection against serious contamination or damage to their terminal installations. At the same time, export and import terminals have recognised the part they can play in maintaining the cleanliness of cargo transfer in protecting downstream units and in safeguarding their own interests.
42.pdf
Download [460 B]
Loss Prevention Bulletin, Cargo Hold Cleaning - West of England P&I [2017, PDF]
Guidelines for Automatic Cargo Tank Overfill Protection Aboard Gas Carriers - SIGTTO [1993, PDF]
Thermowells in LNG Carrier Liquid Lines - SIGTTO [2011, PDF]
A Guide To Contingency Planning For Marine Terminals Handling Liquefied Gases In Bulk - SIGTTO…
Filtration Handbook - MAN Energy Solutions [2023, PDF]
Recommendations for Management of Cargo Alarm Systems - SIGTTO [2019, PDF]
Recommendations for Designing Cargo Control Rooms - SIGTTO [2020, PDF]
Guidelines for the Alleviation of Excessive Surge Pressure on ESD for Liquefied Gas Transfer…
Safety in Liquefied Gas Marine Transportation and Terminal Operations –A Guide for Self-Assessment…
RightShip Inspection Ship Questionnaire (RISQ) - RightShip [2021, PDF]
The time now is: Today 16:46
