twicer ®   07-Sep-2024 11:28
Safety Flashes issues 10-17 May - August, 2024
Year: 2024
Author: IMCA
Genre: Periodical publication
Edition: May - August, 2024
Pages count: Multiple
Description: The International Marine Contractors Association ( IMCA ) Safety Flashes disseminate important information on incidents and potential hazards and the lessons learnt from them that can help prevent incidents occurring elsewhere in the industry.
IMCA Safety Flashes and systems for incident reporting and analysis are an important tool for sharing vital information. By publishing them, IMCA helps its members around the world identify potential hazards, share lessons learned and avoid repetition
IMCA SF 17/24
Non-fatal man overboard: worker fell from height into the sea
LTI – person fell from step ladder
Parted tag line caused damage during lifting operations
Dropped object during cable trans-spooling
Lifeboat air cylinder explosion on an empty installation
Aug 2024
IMCA SF 16/24
LTI: fingers severed by spinning fan blade
Angle Grinder Finger Injury
Crew member cut hand on broken glass during heavy weather
Arm injury from metal skip cover
MSF: Serious hand injury – high pressure air
Aug 2024
IMCA SF 15/24
Side scuttle (porthole) knocked out by wave impact
Dropped object: unsecured cargo inside box broke lose and fell
Load lost from lorry on public road – inadequate securing of cargo
Fast Rescue Boat (FRC) comes close to falling off in a dry dock
MAIB: LTI - a wedge shattered causing injury
Jul 2024
IMCA SF 14/24
Loss of pressure to diver’s primary air supply
Equipment fell on someone’s leg causing injury
Electric shock after water ingress to switch
Emergency musters and drills
Bunker hose damaged during connection
Jul 2024
IMCA SF 13/24
ROV dropped to seabed
UK HSE: Service lifts on offshore and onshore wind turbines
Dropped halogen lamp caused small fire
MAIB: Man overboard – unguarded opening
MAIB: A slip into the hold
Jul 2024
IMCA SF 12/24
Swinging load after loss of position
Dropped welding fume extraction hood
Carriage of Methanol - Dangerous Goods - without proper certification
Personnel exposed to hydrogen sulphide during maintenance
MAIB: Person injured during lifting of compressor
Jun 2024
IMCA SF 11/24
Dropped lifting beam due to parted soft strop
Vessel collided with platform
Diver’s umbilical trapped during a pipeline flooding operation
Stored energy - dislodged pin causes injury
MAIB: Leg injury while mooring
Jun 2024
IMCA SF 10/24
Hand and finger injuries
Crewmember suspended above deck by lifting equipment
CTV crew member snagged on tag line and lifted off feet
Engine failure and subsequent engine room fire
BSEE: Welding and Burning Hazards
SF_10-17 2024
Safety Flashes issues 20-24 (August-October) - IMCA [2023, PDF]
Safety Flashes issues 07-10 (March - April) - IMCA [2023, PDF]
Safety Flashes issues 01-32 - IMCA [2021, PDF]
Safety Flash issue 11/23 (May) - IMCA [2023, PDF]
Safety Flash issue 06 (March) - IMCA [2023, PDF]
Safety Flash issues 24-26/22 - IMCA [2022, PDF]
Safety Flashes issues 16/22 - 19/22 - IMCA [2022, PDF]
Safety Flash issue 21 (October) - IMCA [2024, PDF]
Safety Flash issue 22 (November) - IMCA [2024, PDF]
Safety Flash issue 02 (January) - IMCA [2023, PDF]
The time now is: Today 17:55
