oleyud ®   02-Jan-2014 10:43
Wilhelmsen Ship Service Product Catalogue
Year: 2013
Author: Wilhelmsen
Genre: Catalogue
Publisher: Wilhelmsen
Number of pages: 861
Description: All products listed in this product catalogue form our standard product offer. The full product range will always be available through our online product catalogue at wilhelmsen.com/shipsservice, or wssproducts.wilhelmsen.com.
Here you will find the most up-to-date information, approvals, user instructions and further technical details.
Please be assured, we will always do our utmost to meet your request and take pride in fulfilling your ship’s order requirements.
Our extensive product portfolio, which includes some of the industry’s most trusted and respected brands – Unitor, Nalfleet and Unicool – is aligned to meet all your needs and with global standardisation.
WSS PRODUCT CATALOGUE - TABLE OF CONTENTS
General information 20
Pumps 30
Barrel Pumps 32
Chemical pump lever type 32
1:1 Oil pump with spout 33
2:1 Chemical pump SST316 34
Chemical Applicators 35
10:1 Hydra Clean Chemical Applicator 35
2:1 Chemical applicator 36
Double Diaphragm Pumps 37
Double diaphragm pump 307 polypropylene 37
Double diaphragm pump 515 polypropylene 38
Double diaphragm pump 716 Stainless Steel 39
Double diaphragm pump 1050 polyproplylene 40
Double diaphragm pump 1050 aluminium 41
Double diaphragm pump 1050 Stainless Steel 42
Double diaphragm pump 1590 polypropylene 43
Double diaphragm pump 1590 aluminium 44
Double diaphragm pump 2150 aluminium 45
Double diaphragm pump 2150 Stainless Steel 46
Double diaphragm pump 3275 aluminium 47
Double diaphragm pump accessories 48
Grease Pumps 49
Grease pump 50:1, for 50 kg drums 49
Chemical Applicators Accessories & Spares 50
HP Extendable Lance 5.5 m 50
Double Diaphragm Accessories & Spares 51
Drum suct. kit for 515/716 51
Service kit for 515/716 51
Paint Spraying 52
Airless Paint Spraying Equipment 54
Unitor Hurricane 25D 54
Unitor Hurricane 32 55
Unitor Hurricane 45 56
Unitor Hurricane 73 57
Accessories for Airless Paint Spraying Equipment 58
Polegun for paint spraying 58
Airless Paint Spraying Equipment Acc. 58
Agitator Gallon pail 59
Airless paint spraying gun 59
Consumables for Airless Paint Spraying Unit 60
HD rac tip 60
Throat seal liquid 1 L 60
Rep Kits and Spare Parts for Airless Paint Spraying Equip 61
Rep kit Hurricane 61
Air Tools 62
Air Line Equipment 64
Air hose, PVC 64
Air hose, rubber 64
Air line unit fil/reg/lub 65
Flexible hose 30cm 3/8" 66
Hose clamp for 3/8" hose 66
Air Gun 67
Air gun AG-PRO 67
Deck Scalers 68
Deck planner DP-PRO 200 68
Deck scaler DSH-PRO 11 69
Drills 70
Drill reversible AD-PRO 1800 70
Grinders 71
Angle grinder AG-PRO 4 B version 71
Angle grinder 72
Die grinder DG-PRO 73
Impact Wrenches 74
Impact wrench 74
Needle Scalers & Chipping Hammers 75
Needle scaler JEX-2800 low vibration 75
Needle scaler NS-PRO 19 76
Needle scaler NS-PRO 19 - straight 77
Needle scaler NS-PRO 78
Chisel scaler CS-PRO 79
Chisel hammer CH-PRO 80
Quick Couplers 81
USH socket 81
USM socket 82
USF socket 83
UPH plug 84
UPM plug 85
UPF plug 86
Unitor drain valve 86
Unitor quickview pressure gauge 87
Unitor Medusa air distributor 87
Drills - Accessories, consumables & spares 88
Drill bit set metric - high speed steel 88
Deck Scalers - Accessories, consumables & spares 89
Hammer replacement kit DSH-PRO 11 89
Cutting wheel replacement kit for DP-PRO 200 89
Ear Clamps & Hose Clamps 90
Hose clamp 90
Clamp 1 ear 91
Grinders - Accessories, consumables & spares 92
Plastic pads for AG-PRO 92
Grinding stones set 10 pcs 92
Cutting discs 93
Cutting discs inox 93
Grinding discs 94
Sanding disc 95
Mop discs 96
Impact Wrenches - Accessories, consumables & spares 97
Impact socket set 97
Scalers & Chipping - Accessories, consumables & spares 98
Piston replacement kit 98
Needles for NS-PRO series 98
Scraper for CS-PRO 62 & 120 99
Chisel set for CH-PRO 99
Quick Couplers - Spares 100
Rubber packing for 20-30-40 100
Rubber packing for 400-600 100
Workshop Equipment 102
Wire Lubricator 104
Unitor wire rope lubricator UWL77 104
Unitor wire rope lubricator UWL35 105
Wire Lubricators Accessories 106
Lubricator chamber for UWL35 106
Lubricator chamber for UWL77 106
Seal kits for UWL35 106
Seal kits for UWL 77 107
Working Lamps 108
Lamp cordless F/7.2-12 V batteries 108
Saws & Cutters 109
Circular saw, 160 mm 109
Jig saw 110
Bench cutter 111
Drills 112
Battery drill 12 V 112
Drill, chuck size 1-10 mm 113
Drill, chuck size 3-16 mm 114
Percussion drill PD2E 22 R 115
Grinders 116
Angle grinder 5", 10000 rpm 116
Angle grinder 7", 8500 rpm 117
Angle grinder 9", 6600 rpm 118
Drills 119
Drill bit set imperial - high speed steel 119
Battery nicd 18 V/2.0A 119
Battery charger 7.2-24 V/50-60HZ 119
Cutter 120
Hydraulic nut splitter 120
Flange Spreader 121
Hydraulic flange spreader 121
Pump & Cylinders 122
Hydraulic pump cylinder set 122
Hydraulic pump low cyl. set 123
Hydraulic cylinder 124
Hydraulic cylinders 125
Hydraulic pump electric 230VAC 125
Hydraulic pump, air roper, max 700bar 126
Hydraulic cylinder, 50T 127
Hydraulic hand pump, max 700 bar 128
Accessories for Hydraulic Equipment 129
Gauge, hydraulic 129
Regulator-filter-lube 129
Tension meter, cap. 4.5 T 130
Hydraulic cutter head, cap. 20 T 130
Replacement blade 131
Hydraulic hose for high pressure 131
Hydraulic coupler 131
Fittings - Adaptor, Hexagon nipple, Coupling, Cross, Tee & Reducer 132
Gauge, hydraulic pressure 133
Valve, flow control 133
Cleaning Equipment 134
HP Cleaners 150 - 220 bar 136
High pressure cleaning 136
HP Cleaner HPC 30, 1x220 V/60 Hz 138
HP Cleaner HPC54 200 bar, 3x220-380 V/50 HZ 140
HP Cleaner HPC54 200 bar, 3x220-440 V/ 60 HZ 142
HP Cleaner HPC62 220 bar, 220-440 V/60 HZ 144
HP Cleaner HPC66 190 bar, 3x220-440 V/60 Hz 146
HP Cleaner HPC66 190 bar, 3x220-380 V/50 HZ 148
Spares/Accessories - Cold Water HP Cleaners 150 - 220 149
Deck hose low friction 25 m 149
Heavy duty hose 10 m 150
Heavy duty hose 15 m 151
Heavy Duty Hose 25 m 152
3
Non blackening hose 10 m 153
Non blackening hose 25 m 154
Chemical Injector 155
Double lance 200 cm 155
Drain cleaner complete kit with 20 m hose 156
Foam Injector 156
Foam Lance 157
Hose quick coupling set 157
HP Extendable Lance 5.5 m 158
Nozzle 06/25 for Extendable Lance 158
Stainless Steel Cleaning Trolley 159
Rotary Brush 80 cm 159
Rotary Brush 170 cm 160
Spray handle 3000 160
Tornado Short Lance 10 cm 161
Tornado Normal Lance 92 cm 161
Powerspeed Lance 162
Tornado normal lance 104 cm 162
Nozzle 05/25 degree for Extendable Lance 163
Nozzle 06/0 degree for Extandable Lance 163
Nozzle 05/0 degree for Extendable Lance 163
Universal 3000 Lance 164
Washing Brush 235 cm 164
Hot Water HP Cleaners 165
HP Cleaner HPCH53 HW, 200 bar 60 HZ 165
Spares & Accessories for Hot HP Cleaners 167
Rotary Brush 80 cm 167
Repair kit safety valve HPCH53&Solar 167
Repair kit bypass valve for HPCH53 167
HP Cleaners 300 - 500 bar 168
HP Cleaner HPCE330 310 bar, 3x440/60 Hz 168
HP Cleaner HPCE405 385 bar, 3x440 V/60 Hz 169
HP Cleaner HPCE520 500 bar, 3x440 V/60 Hz 170
HP Cleaner HPCE520 high flow 500 bar, 3x440V/60 Hz 171
Air Driven HP Cleaners 172
HPC Airclean 25 172
HPC Airclean 32 173
HPC Airclean 48 174
Spares & Accessories for HP Cleaners 300 - 500 bar 175
Powerspeed Attachment, HPCE330 175
Sandblasting Pack, HPCE330 and 405 175
Powerspeed Attachment, HPCE520 176
Sandblasting Pack, HPCE520 176
Water filter insert extreme 177
Extreme High Pressure hose - 10 m 177
Extreme High Pressure hose - 25 m 178
Spares & Accessories for Air Driven HP Cleaners 179
Single Lance HPC Airclean 179
High Pressure hose, HPC Airclean 179
Stationary Cold Water Cleaners 180
Duo booster 3X440 V 60 HZ 160 BAR 180
Delta booster-3 3X440/60 182
Delta booster-4 3X440/60 184
Delta booster-5 3X440/60 186
Delta booster-6 3X440/60 188
Uno booster 3X440 V 60 HZ 160 BAR 190
Spares & Accessories Cold Water Stationary Systems 191
Take off valve A for sationary acid proof 316 191
Take off valve A for stationary Chromium plated brass 191
4
Stationary Hot Water Cleaners 192
Solar booster with 18 KW heater, 3x440 V/60 Hz 192
Solar booster with 18 KW heater, 3x400 V/50 Hz 194
Wet & Dry Cleaning Units 195
VCWD20 wet and dry vacuum cleaner 195
VCWD70 wet and dry vacuum cleaner 196
VCWD27 wet and dry vacuum cleaner 198
VCAD200 wet and dry vacuum cleaner 199
Accessories & Spares Vacuum Cleaners 200
Suction hose 1.8 M for VCWD18 200
Straight tube VCD15 & 27 200
Water hose & suction hose fro VCCW24 200
Carpet nozzle for VCCW24 200
Deck scrubbing adapter for VCCW24 200
Suction hose 4m for VCWD 70 201
Large deck cleaning kit for VCWD 70 201
Liquid removal kit for VCWD 70 201
Curved tube 100 cm for VCWD 70 201
Mucking Pumps 202
Mucking Pump - Marine GM2 202
Mucking Pump - Accessories, consumables & spares 203
Vacuum kit for mucking pump 203
Camloc connector 102 mm table D fleng for mucking pump 203
TPI connectors for mucking pump 203
Butterworth connectors for mucking pump 203
Cargo Hold Cleaning Kit 204
Cargo Hold Cleaning Kit - Handymax 204
Cargo Hold Cleaning Kit - Panamax Light 205
Cargo Hold Cleaning Kit - Panamax 206
Cargo Hold Cleaning Kit - Accessories, consumables & spares 207
Extension for chemical applicator lance 207
Cleaning Jets 208
Tornado 2 Cargo Hold Cleaning Jet 208
Tornado 3 Cargo Hold Cleaning Jet 209
Tornado 4 Cargo Hold Cleaning Jet 210
Ultrasonic 211
Unitor Ultrasonic Cleaner S-700/HM, 110 V 211
Unitor Ultrasonic Cleaner S-700/HM, 230 V 212
Unitor Ultrasonic Cleaner S-1600/HM, 230 V 214
Unitor Ultrasonic Cleaner S-2000/HM, 230 V 215
Unitor Ultrasonic Cleaner S-3300/HM, 440 V 216
Multi-Frequency Generator, MF 2000 217
Multi-Frequency Generator, MF 3000 218
Multi-Frequency Generator, MF 4000 219
Immersible Ultrasonic Transducer, MF-TS 600 220
Immersible Ultrasonic Transducer, MF-TS 1000 221
Immersible Ultrasonic Transducer, MF-TS 1500 222
Immersible Ultrasonic Transducer, MF-TS 2000 223
Gases, refrigerants and cylinders 224
Acetylene 226
Acetylene A-40 filling 226
Acetylene A-5 filling 227
Oxygen 228
Oxygen O-40 filling 228
Oxygen O-5 filling 229
Nitrogen 230
Nitrogen N-5050 filling 230
Nitrogen N-5030 filling 231
Nitrogen N-1050 filling 232
5
Nitrogen N-1030 filling 233
Cruise gas 234
Propane P-5 filling 234
Helium H-40 filling 235
Carbon dioxide filling 236
Nitrogen food Grade N-10FG filling 237
Breathing oxygen 238
Breathing oxygen MOX-2 filling 238
Breathing oxygen MOX-5 filling 239
Breathing oxygen MOX-40 filling 240
Argon 241
Argon E-50 filling 241
Argon E-10 filling 242
Unimix 20 M-10 filling 243
Unimix 20 M-50 filling 244
Nitrogen mixtures 245
Ammonia 245
O2 in Nitrogen in SG10 cylinder 246
CO2 in Nitrogen/air in SG10 cylinder 247
Ethanol 248
Disposables 249
MInimix Disposable Cylinders 249
LEL mixtures 250
LEL mixtures 250
Pentane 49% LEL in air C5H12 (0.68% vol) in SG50 cylinder 252
Regulators 253
Regulator R-510 for Spangas SG10 cylinders 253
Regulator for Scotty 58/VI disp. cylinder 253
Regulator for Minimix disposable cylinder 253
Bracket for SG10 cylinder 253
Hycool marine 254
Hycool marine 45 254
Hycool blue additive 25 L can 254
R-134a 255
Unicool R-134a 57 kg refrigerant 255
Unicool R-134a 12.5 kg refrigerant 256
R-22 257
Unicool R-22 57 kg refrigerant 257
Unicool R-22 12.5 kg refrigerant 258
R-404A 259
Unicool R-404A 45 kg refrigerant 259
Unicool R-404A 9.5 kg refrigerant 260
R-407C 261
Unicool R-407C 52 kg refrigerant 261
Unicool R-407C 11 kg refrigerant 262
R-410A 263
R-410a 45 kg refrigerant 263
R-410A 9.5 kg refrigerant 264
R-417A 265
Unicool R-417A 51 kg refrigerant 265
Unicool R-417A 11 kg refrigerant 266
R-422D 267
Unicool R-422D 52 kg refrigerant 267
R-427A 268
Unicool R-427A 53 kg refrigerant 268
R-507 269
Unicool R-507 45 kg refrigerant 269
Unicool R-507 9.5 kg refrigerant 270
Refrigerant recovery cylinders 271
6
Recovery cylinder 21,6 l + documents 271
Recovery cylinder 56 l + documents 272
Complete installations for Ox/Ac 273
Central installation for Acetylene + Oxygen 273
Cylinder racks 274
Rack for cylinders 274
Gas cylinder cabinets 275
Gas Cylinder cabinet 275
High pressure components 276
Low pressure components 277
Low pressure components spare parts 277
Leak detection spray 300 ml 278
Outlet station 279
Outlet station 700 complete with S55 flashback regulators and steel cabinet 279
Outlet station 700 with steel cabinet but without flashback arrestors 279
Steel cabinet for outlet station 700 280
Fibre glass cabinet for outlet station 700 280
Adaptor set for outlet station 700 281
Twin valve unit for outlet station 700 281
Regulator R-530 for Acetylene 282
Regulator R-530 for Oxygen 282
Stretch relief bracket for twinhose 283
Shielding gas installations 284
Shielding gas installation for cylinders 284
Refrigeration equipment 286
Lubricants 288
Refrigerant oil, POE, low temperature 288
Refrigerant oil. Poe, high temp 289
Refrigerant oil, mineral, high temp 290
Package Equipment 291
Unitor drinking water cooler, 230 V 291
Unitor drinking water cooler, 115 V 292
System Equipment and Accessories 293
Refrigerant charging station UCS-200 293
Liquid line drier core 48 DN 294
Charging hose HP 1350 mm 294
Cylinder stand 295
Top valve adaptor set for Unicool refrigerant cylinders UVA-001 295
Collection of fittings, 1/4 - 3/8" 296
Collection of fittings, 3/8 - 5/8" 297
Fixed leak detector kit, 4 channel, MRD4S-2L 298
Fixed leak detector kit, 6 channel, MRD6S-2L 300
Fixed Leak detector Kit 4 Chanels IP66 302
Fixed leak detector, MSPH sensor 303
Fixed leak detector, IP66 sensor 304
Fixed leak detector, safety V/V vent pipe sensor 305
Fixed leak detector, AHU/DUCT sensor 306
Fixed leak detector, 4 core cable 306
Tools 307
Digital dual thermometer 307
Marine thermometer kit UTK-100 308
Surface probe thermometer 310
Air probe thermometer 310
Needle probe thermometer 311
Wire thermocouple probe 311
Inrafred thermometer 312
Vacuum pump, standard, 115/230 V 313
Vacuum pump, Heavy duty, 115/230 V 314
7
Vacuum pump oil 0.95 l 315
Vacuum gauge 0-1000 MBAR 315
Digital vacuum gauge UVG-64 316
Electronic vacuum gauge UVG-150 317
Charging/Vacuum Hose UCH-72Y 318
Vacuum valve assembly 319
Hand oil pump 5 L & 25 L drums 320
Acid test kit mineral + AB oils 320
Acid test kit poe oils 320
Refrigerant leak detection kit, UV tracer kit 220/240 V 321
Refrigerant leak detection kit, UV tracer kit 12 V 322
Refrigerant leak detection, UV, tracer fluid for mineral oil 323
Refrigerant leak detection, UV, Universal tracer fluid for all oil types 324
Refrigerant leak detection, UV, glo-klenz cleaner 324
Spare bulb 110/220 V 100 W 325
Spare bulb 12V 100W 325
Hand held refrigerant leak detector UNIRX-1A 326
Maintenance kit leak detector-XP2 327
Refrigeration handy tools case 328
Tube cutter UPT-274-FC 329
Tube bender, triple head 329
Flare tool 330
Flaring set 330
Flare/Swage set 3/16" - 3/4" 331
Inner-outer reamer 331
Ratchet Wrench Small 1/4" - 3/8" - 3 & 5/16" 332
Ratchet Wrench Big 1/2" - 1/4" - 5 & 9/16" 332
Magnet & Volt Sticks Pack 333
Charging hose set UCH-72 3 x 1.8 m 333
Deluxe service manifold set 2-WAY, R-410A 334
Deluxe service manifold set 4-WAY, various refrigerants 335
Refrigerant recovery package, 115 V 336
Refrigerant recovery package, 230 V 338
Refrigerant recovery unit, URU-5000B, 115 V, 50/60 HZ 340
Refrigerant recovery unit, URU-5000A, 230 V, 50/60 Hz 342
Recovery unit URU-5000A/B, compressor repair kit 344
Recovery unit URU-5000A/B, piston seal repair kit 344
Recovery unit URU-5000A/B, valve repair kit 344
Recovery unit URU-5000A/B, shaft seal repair kit 344
Recovery unit URU-5000A/B, connection kit 345
Recovery unit URU-5000A/B, inlet filter drier 3PCS, 1/4" Flare 345
Digital weighing platform ADS-100 346
Onboard storage box for refrigerant recovery package 347
Charging Hose - 1.8 m, 1/4" Flare 9881268 Cl-72-Y Yellow 347
Filter driers UFD 2 PCS 348
Activated alumina beads 349
Silica gel desiccant 349
Welding 350
Gas Cylinder Regulators and Flashback Arrestors 352
Regulators 510 352
Flashback arrestor W-66S 353
Flashback arrestor S55 354
Gas Hoses and Couplings 355
Gas hoses 355
Reel, self retracting with 20m 6.3 mm twin hose Ac/Ox 356
Reel with crank for welding cable and gas hoses 356
Hose joint for gas hoses 357
hose clamp 357
Pincher tool for hose ear clamps 357
8
Quick couplings 358
Gas Welders Accessories 359
Safety welding goggles, lift front for gas welding 359
Glasses for gas welding goggles 359
Safety spectacles clear for eye protection 360
Safety spectacles shade 4 for brazing and gas welding 360
Safety grinding goggles with anti mist acetate lens 361
Heat resistant mitten for gas cylinders 362
Gas/TIG softskin welding gloves, 6 pairs 362
Gas ignitor triplex 2 pcs for gas welding 363
Gas ignitor triplex spare flint set. 10 pcs 363
Welders chalk, flat 5x13x127. 144 pcs/pack 364
Temperature indicator kit 364
Galvanizing spray. 6 pcs 364
Welding, Brazing & Cutting Torch 365
UCT-500 Combination torch master kit for gas welding/cutting 365
UCT-500 combination torch compact kit for gas welding/cutting 366
Shank with non-return valves for Ac/Ox combination torch 367
Nonreturn valve 367
Welding attachments 368
Multiflame heating attachment 368
Cutting attachment with head angle for UCT-500 369
Cutting nozzle 370
Gouging nozzle 370
Guide standard 371
Spare part kit complete 371
Spanner for torch 372
Cleaning needles set for torch 372
Transportable Gas Welding Equipment 373
Trolley A40/O40 gas weld. 373
Trolley 1 SU-10 374
Trolley A-5/O-5 gasweld for portable equipment 375
Back portable rack f/A5- +05-cyl. 376
Portable rack for A5+05 cylinder 377
Standard gas accessories for mobile equipment 378
Portable welding table 379
Gas Welding Cabinet 380
Gaswelding cabinet empty 380
Gaswelding cabinet complete with torch, rods & fluxes 381
Gas Welding and Brazing Consumables 382
Gas welding and brazing consumables 382
Arc welding/cutting machines 384
UWI-150 Autoline Welding Inverter 384
UWW-161 MP Multi Process Welding Inverter 386
UWI-203 Stick / TIG 388
UWR-303 welding rectifier 390
Accessories for UWR-303 392
UWI-400 welding inverter 393
Accessories for UWI-400 395
UWF-SC 12 RC wire feeder 396
UWR-852 Welding rectifier 398
UPC-1041 Plasma Cutter 400
Cables and Connectors 402
Welding cable 402
Cable connector 403
Cable shoe 403
Adapter Plug Dix Female 70 and Male 25; 2 pcs per pack 404
Parallel connecting three way connector DIX70 male-female-female 2 pcs 404
Conversion assem. 2 pcs 404
9
Remote control for UWR-303 with belt clip 405
Remote control cable 10m for UWR-303 405
Extension cable 25m 4 PIN for UWR-303 remote controls 406
Remote control for UWI-400 for el holder/tig torch 406
Extension cable a 25 m for UWI-400 remote controls 407
Parallel connection cable for UWI-400 remote controls 407
Stick electrode arc accessories 408
Electrode holder assembly 408
Electrode holders 408
Air carbon arc torch 600A with safety and air connection 409
Air carbon arc torch heavyduty 1600A 409
Return clamp assembly 410
Return clamps 410
TIG Welding Accessories 411
TIG welding accessories 411
TIG torch-T-150 w dix 25 connector 412
Remote control for UWI-150 autoline 413
TIG Torch T-161 with 4 m cable, euro connector and torch mounted trigger 414
TIG torch T-200 w dix 70 connector 415
Accessories kit TIG torch 417
Tungsten electrode 1.6mm alloyed for DC TIG welding 418
Tungsten electrode 2.4mm alloyed for DC TIG welding 418
Wire Welding Accessories 419
Wire torch T-400 with 3m cable for S-12RC/S-22 P12/UWF-MP 419
Driveroll and wire guide kits for wire feeder sc 12 rc 420
Spool compression spring 421
Spool adapter 421
Wire torch M-161 with 3m cable and euroconnector for UWW-161 MP 422
Drive roll 422
Shielding gas accessories 423
Argon regulator 423
CO2 regulator 424
Flowcontrol needle valve for gas flow adjustment 425
Flowcontrol meter, argon for use at torch nozzle 425
Plasma cutting accessories 426
Consumables kit complete for UPC-1040 426
Accessories for UPC-1040/1041 426
Current distribution system 427
Inlet station welding current 400A 428
Outlet station welding current 400A 429
Inlet station welding current 800A 430
Outlet station welding current 800A 430
Remote connection cable for UWI-400 6m, 14 pin female/10 pin male 431
Remote connection cable for UWR-303 6m, 4 pin male/10 pin male 431
Remote control adapter for UWI-400 14 pin female/10 pin male 432
Remote control adapter for UWR-303 4 pin female/10 pin male 432
Welder's Protection 433
Autovision Plus Fresh Air Weldshield with respiratory unit 433
Autovision plus welding shield 434
Flipvision welding face shield with headband and shade 11 glass 435
Safety helmet with face shield and shade 11 glass 436
Face shield with handle and filter shade 11 glass 437
Arc welding glasses 438
Autovision outside cover lens 10pcs 438
Autovision inside cover lens 10pcs 438
Protective clothing 439
Welding curtain with hooks 440
Welding spatter blanket 1 x 10mm on roll 440
10
Fume Clean 230 complete 441
Welder's Tools 442
Wire Brush 442
Chipping hammer 442
Welding gauge type J for throat thickness and reinforcement 443
Multi purpose plier for wire torch 443
Welders chalk, flat 5x13x127. 144 pcs/pack 444
Temperature indicator kit 444
Galvanizing spray. 6 pcs 444
Anti spatter spray, 400 ml in a box, 6 pcs 445
Magnaflux crack detection kit 446
Cleaner SKC-S. 10 pcs 447
Penetrant SKL-SP1. 10 pcs 447
Developer SKD-S2. 10 pcs 447
Information about coated stick electrodes 448
Coated Stick Electrodes 450
Unitor range of maintenance electrodes 450
GPO-302N 453
GPR-300H 454
Special-303N 455
LH-314N 456
LHH-314H 457
LHV-316N 458
LHT-318N 459
LHL-319N 460
LHR-320N 461
18/8-321N 462
23/14-322N 463
Duplex-325N 464
Pickling gel 2 litre for stainless steel 465
Tensile-328N 466
Impact-329S 467
Wearmax-327 468
Abratech-330 469
Nickel-333N 470
NiFe-334N 471
Tinbro-341 3.2x350mm 42 electrodes 1.4kg 472
Albronze-344 3.2x350mm 46 electrodes 1.3kg 472
Alumin-351N 3.2x350mm 82 electrodes 1.1kg 473
CH2-382 3.2x350mm 36 electrodes 1.4kg 474
ACA-384 475
Electrode Storing Cabinets 476
Minidryer- 350 capacity 8kg electrodes 476
Heating cabinet - 85 capacity 350kg electrodes 477
Electrode cabinet empty for 27 pcs electrode packages 478
Electrode cabinet complete with 27 pcks of electrodes 479
Arc Welding Wires 481
Wire for wire welding 481
TIG Welding Rods and Fluxes 482
Rods and fluxes for TIG Welding 482
Cold Repair Polymer Compounds 483
Cold repair polymer compounds 483
Polymer kit 484
Leak stop pipe repair tape 485
Metalgrade ready stick 3 pairs of sticks 0.72kg 486
Metalgrade express base and activator 0.25L 486
Metal grade rebuild base and activator 0.5L 487
Metal grade hi - temp heat resistant compound 488
11
Aquagrade rebuild base and activator 0.5L 489
Ceramigrade rebuild base and activator 0.5L 490
Ceramigrade liner base and activator 0.5L 490
Ceramigrade abrashield 5.4kg engineering repair compound 491
Rubbergrade 6 rebuild 3 x 0.143L base/activator 492
Rubbergrade 6 remould 3 x 0.143L base/activator 493
Marine Chemicals 494
Cleaning Chemicals 494
Cargo Hold Cleaning 496
Aquatuff High Foam 496
Metal Brite HD 497
Slip-Coat 498
Slip-Coat WR 499
Cleaning and Maintenance 500
Enviroclean 500
Coldwash HD 501
Cleanbreak 502
Seaclean 503
Seacare O.S.D 504
Seacare Ecosperse 52 505
ACC Plus 506
Air Cooler Cleaner 507
Carbonclean LT 508
Carbon Remover 508
Descalex 509
Descaling Liquid 510
Metal Brite 511
Disclean 511
Deck Clean NP 512
Teak Renewer 512
Aquatuff 513
Aquabreak PX 514
Foam-Agent 515
Multi clean 515
Reefer Cleaner 516
Fore & Aft 517
H.P. Wash 518
Uni-Wash 519
Ultra Sonic Cleaner USC 520
Natural Hand Cleaner 521
Carpet Cleaner 522
UltraCIP 523
Commissioning Cleaner 524
Bilge Water Flocculant 525
Defoamer Concentrate 526
Penetron Plus 527
Electrosolv-E 528
Mud & Silt Remover 528
Tank Cleaning 529
Seaclean plus 529
Alkleen Liquid 530
Alkleen Safety Liquid 531
Tankleen Advance 532
Tankleen Bright 532
Unipol 533
Zinc Coat Conditioner 534
Gamazyme Cleaners 535
Gamazyme 700FN 535
Gamazyme MSC 536
12
Gamazyme BTC 537
Gamazyme TDS 538
Gamazyme Digestor 539
Gamazyme DPC 540
Gamazyme BOE 541
Gamazyme FC 542
Gamazyme BUB 543
Water Treatment 544
Boiler Water Treatment 546
Oxygen Scavenger Plus 546
Oxygen Control 547
Oxygen scavenger 9-035 548
Oxygen scavenger 9-002 548
Oxytreat 549
Cat Sulphite L (CSL) 550
Condensate Control 551
Condensate treatment 9-150 552
Hardness treatment 7208 552
Hardness Control 553
Alkalinity Control 554
BWT liquid plus 555
Boiler Coagulant 556
Autotreat 25 557
Multiplus 558
Liquitreat 559
Combitreat 560
Cooling Water Treatment 561
Antifoulant 9-321 561
Rocor NB Liquid 562
Engine water treatment 9-108 563
Nalfleet 2000 564
Dieselguard NB 565
Engine Water Treatment 9-111AL 566
Cooltreat AL 567
Mar-71 568
Bioguard 569
Water Production Treatment 570
Vaptreat 25 L 570
Maxi-vap plus 570
Multivap 571
Evaporator defoamer 572
Potable water stabiliser liquid 573
Potable Water Stabiliser 574
RO Scale control 575
RO Bisulphite 575
RO Alkaline cleaner 576
RO Mild acid cleaner 577
RO Surfactant cleaner 577
Ballast tank inhibitor 9-933 578
Aquabrome tablets 578
Pool Clarifier 579
Pool Surface Cleaner 580
Pool and Spa Hardness 581
Spa Defoamer 582
pH Increaser 583
Fuel Oil Treatment 584
Distillate Fuel Treatment 586
Biocontrol MAR 71 586
Diesel fuel lubricity improver 587
13
Diesel fuel stabiliser 588
Heavy Fuel Oil Treatment 589
Fuelcare 589
Gamabreak 590
Dual Purpose Plus 591
Burnaid 592
Dieselite 593
Valvecare 594
Soot Remover 595
Soot Remover Liquid 596
Test Kits & Equip m e n t 597
Nalfleet Water Dosing Equipment 600
Naltrak 1000 CWT dosing system 600
Naltrak 1750 BWT dosing system 601
Naltrak 2000 BWT dosing system 602
Dosing unit for Evaporator Treatment 603
Dosing unit for BWT 604
Sea Water Dosing Unit 605
Nalfleet Water Test KIts 606
Spectrapak 309 606
Spectrapak 310 607
Spectrapak 311 608
Spectrapak 312 609
Spectrapak 313 610
Spectrapak 315 611
Motor ship test kit 612
Boiler plus test kit MO380 613
Sulphite drop test 614
Nitrite full kit MO248A 615
pH test strips 2 pack MO319 616
Total hardness titration pack M204 616
Alkalinity titration pack M250 617
Chloride titration pack M251 617
Titration apparatus pack no 1 MO217 618
Titration apparatus pack no 2 MO218 618
Filter pack, 1 cardboard box MO213 619
Ecoscan pH6 meter & electrode MO348 619
Ecoscan conductivity meter MO347 620
Maxidirect photometer 621
Chlorine checkit block 0.2-8 ppm 622
Oxygen full kit 0-40 ppm O2 M341 622
Legionella test kit 623
Potable Water Test Kit 624
Lovibond 2000 comparator 625
Test kit cooltreat AL with CL test 626
Unitor Cleaning and Dosing Equipment 627
Fuel Oil Treatment Dosing Unit 627
Automatic Dosing for Soot Remover Liquid 628
Manual Dosing Unit for Soot Remover Liquid 629
Portable Soot Remover Injector 630
Fixed Soot Remover Injector 631
Chemical Cleaning Unit 632
Jet spray unit 10 l ste 633
Jet spray unit 10 l stainless steel 633
Rechargeable sprayer 634
Spray gun 1 l 635
Syphon squeezer 635
Unitor Fuel Oil Test Kits 636
Easy Ship Combined Oil Test Kit 636
14
Easy Ship Water in Oil Test Kit 637
TBN Test Kit 638
Compatibility Test Kit 639
Heated Viscosity Meter 640
Density Meter 641
Fuel Oil Test Cabinet 642
Insolubles Test 643
Salt Water Determination Test 643
Bunker Sampler 644
Plastic Storage Cabinet 645
Fire Protection 646
Cabinets for Extinguishers and Fire Blankets 652
Cabinet for fire extinguisher 6 to 9 kg 652
Cabinet for Fire Extinguisher 5 to 9 kg 653
Fire Blanket 120 X 180 cm wall-mounted 654
Portable Extinguishers Cartridge Operated 655
Powder Extinguisher 12 kg Abc without Bracket - P12p M18 655
Powder Extinguisher 9 kg Abc without Bracket - P9p M18 656
Powder Ext. 6 kg Abc W/O Brkt - P6p M18 657
Water Extinguisher 9 L without Bracket E9 Model E9 658
Foam Extinguisher 9 l without Bracket 659
Metal Fire Extinguisher 9 kg without Bracket - P9fm.M M18 660
Foam Extinguisher 9 l without Bracket Ev Low Tmp.Hi Type E9a1ev Lt Hp 662
Fat Fire Extinguisher 6 L without Bracket Model E6a15 Evf 663
Stored Pressure Extinguishers 664
Powder Extinguisher 2 kg Abc W/Spc with Bracket Model Pp2p 664
Dp Extinguisher 3 kg Abc Pp3p Sp without Bracket 665
Co2 Extinguisher 5 kg without Bracket Model U5c 666
Dp Extinguisher 6 kg Abc Pp6p Sp without Bracket 667
Dp Extinguisher 9 kg Abc Pp9p Sp without Bracket 668
Dp Extinguisher 12 kg Abc Pp12p Sp without Bracket 669
Wheeled Extinguishers 670
Powder Extinguisher 50 kg Abc P50p Wheeled 670
Extinguisher Co2 20 kg Wheeled 671
Foam Extinguisher 45 l Wheeled Model E45a2 672
Foam Extinguisher 135 l Wheeled Model E135a2 673
CO2 Extinguisher 45 kg Wheeled 674
Powder Extinguisher 25 kg Abc Wheeled P25p Me 675
Co2 Extinguisher 9 kg Wheeled 676
Extinguisher Powder 25 kg Wheeled 677
Spare parts for fire extinguishers 678
CO2 Cartridge 60 g for 9 L Water/ Foam E9/E9A1/E9A1EV extinguisher 678
Co2 Cartridge 450 g for foam 45 L Extinguisher 679
CO2 Cartridge 2 kg for 135 l foam Extinguisher 680
CO2 Cartridge 120 g for 6 kg Powder Extinguisher 681
Spare Cartridge 160 g for 6 kg Powder (BC rated) Extinguisher 682
CO2 Cartridge 180 g for 12 kg Powder Extinguisher 683
CO2 cartridge 450 g for 25 kg Powder (ABC or BC rated) Extinguisher 684
CO2 Cartridge 900 g for 50 kg Powder (ABC or BC rated) Extinguisher 685
AFFF Foam Charge 90 ml for 9 L Foam Extinguisher 686
AFFF Foam Charge F/E45a2 2300011-0.9 l 687
AFFF Foam Charge 3 x 0.9 L for 135 L Foam Extinguisher 688
Powder Refill for 6 kg ABC Extinguisher 689
Powder Refill for 9 kg ABC Extinguisher 690
Powder refill for 12 kg ABC Extinguisher 691
Powder Refill for 25 kg ABC Extinguisher 692
Marine bracket with strap for 5 kg CO2 Extinguisher 693
Universal Bracket For P6/P6p/P9p/ P12/P12p/E9/E9a1 693
Marine Bracket With Strap For Pp6p 694
15
Marine Bracket With Strap For PP9P 694
Extinguisher Bracket with Strap for 12 kg Stored pressure 695
Fire Couplings 696
Norwegian coupling 696
Storz Coupling 697
Instantaneous coupling 698
Fire Hoses 699
Martex Fire hose 699
Guardman fire hose 700
Mertex fire hose 701
Clamping device for binding machine 702
Binding Machine Portable 702
Fire Hydrants 703
Hydrant Valve 703
International Ship to Shore connection 704
Fire Nozzles 705
Fire nozzles 705
Foam Concentrates 706
Foam concentrates 706
Smoke and Heat Detector Test Equipment 708
Smoke and Heat Detector testing 708
Personal Safety 710
Breathing Air Compressors 712
Junior II-E Air Compressor 713
Oceanus E Air Compressor 714
Breathing Air Compressors B Timer 715
Compressor Filter charge for Junior/Oceanus TRIPLEX filter 716
Bauer Compressor Filling Hose 50 m Dn6, Pn450 717
Compressor 300-200 bar change over device 718
Change over Device from 200-300 bar Compl For Bauer Compressor 718
Compressor Breathing Air Quality Test Kit 719
Filter Masks / Breathing Filters 720
Breathing Filter Masks 720
ADVANTAGE 3121 Single Filter Threaded Med. 721
Breathing Masks Filter Range 722
Compressed Air Breathing Apparatus 723
Self Contained Breathing Apparatus 723
Emergency Escape Breathing Device 724
Uniscape EEBD 724
Chemical Protection 726
Chemical Suits 726
Chemical Resistant Personal Protection Kit 727
Trellchem Super T-ET 728
Trellchem Light T 729
Trellchem VPS T-ET 730
Trellchem Splash 600 suit without boots 731
Unipack hose for Chemical suits Super/VPS/Light suit only connection 732
Unipack hose for Chemical suits Super/VPS/Light suit and rescue mask connections 732
Chemical Suit Safety Boots 733
Trellchem Chemical suit Hood for Facemask & BA set 734
Trellchem Chemical suit mini hood 734
Gloves, viton/butyl for Trellchem VPS & Super 735
Gloves PVC for Trellchem light and splash 736
Chemical Suit Repair kits 737
Molykote grease f/O-ring bayonet system 738
Head Protection 739
Head Protection 739
Head Protection Accessories 740
16
Hearing Protection 741
Personal Fire Protection 742
Unitor Flameguard Plus firefighter suit kit 742
Unitor Flameguard Solas firefighter suit 743
Unitor Firebuddy plus firefighter suit kit 744
Firemans Helmet - PAB HT04 745
Led lamp for fireman helmet PAB 746
Cabinet for Fire fighters outfit 747
Fire axe with insulated handle 2 kV 748
Cover for Fire Axe 748
Gloves for Firebuddy Plus Firefighter suit 749
Firefighters suit insulated gloves 750
Solas Firefighter Boots 751
Firefighter Boots - MED Approved 752
Firefighter Lifeline 753
Portable Gas Detection 754
Oxy, Toxi & Gas-mate 754
Combi-Mate 755
Combi-Mate 3 757
Tank-Mate 758
Aspirator hose 10 m for use with Unitor Gas detectors 759
Aspirator hose 20 m for use with Unitor Gas detectors 759
Aspirator probe 1 m fixed for gas detection 760
Aspirator Probe, Telescopic - 1 m 760
Aspirator assembly Single Gas Monitor 761
Aspirator assembly non-pumped Unitor Combi-Mate gas detector 761
Aspirator Assembly for Unitor Combi-mate 3 gas detector 762
Watertrap for use with gas detection aspirator tube 762
Gas-Test Kit, for Unitor Combi-Mate pumped unit without gas cylinder 763
Gas test kit for Combi-mate 3 763
Carry Case for Oxy, Toxi & Gas-mate Single Gas portable gas detector 764
Carry Case for Unitor Combi-Mate portable gas detector 764
Chest harness kit for Unitor Combi-Mate gas detector 765
Carry Case for Unitor Combi-mate 3 portable gas detector 765
Carry case and belt for Unitor Tank-mate gas detector 766
Harness Belt and Fall Arrestor 767
Fall Arrest devices 767
Life Saving 768
Cabinets 770
Cabinets 770
Hydrostatic Release Units 771
Hydrostatic Release Unit Hammar H20 for liferafts 2 year 771
Hydrostatic Release Unit DK2004 for liferafts 4 Year 772
Immersion Suits 773
Immersion Suits 773
Rescue suit 774
Life Jackets and Lights 775
Lifejacket Ancillaries 775
Inflatable Lifejackets 776
Unitor Seaguard Lifejackets 777
Lifebuoys, bracket, lines and light 778
Lifebuoys and Ancillaries 778
Lifebuoy Lights 779
Lifeboat Air Cylinders 781
Lifeboat cylinders 781
Liferafts 782
Liferaft Rental 782
Throwoverboard Liferafts 784
17
Davit Launch Liferafts 786
Pyrotechnics 788
Pyrotechnics 788
Rescue Equipment 789
Stretchers 790
Neil Robertson Stretcher 790
Paramedic Stretcher and Rescue Unit 791
IMO Embarkation station/Lifeboat signs 792
IMO Lifeboat Signs 792
IMO Escape Way guidance signs 793
Escape way and guidance signs 793
IMO Fire fighting Equipment & System signs 794
Fire Equipment signs 794
IMO First Aid & Safety Equipment signs 795
First Aid and Medical Equipment signs 795
IMO Hazard signs 796
IMO Hazard Signs 796
IMO LSA Signs 798
IMO Lifesaving Appliance Signs 798
IMO Muster/Assembly station signs 800
Muster and Assembly station signs 800
IMO Personal Protective Equipment signs 802
Personal protective equipment Signs 802
IMO Prohibition signs 803
IMO Prohibition Signs 803
IMO Security Instruction signs 804
IMO Security instruction Signs 804
IMO SOLAS tape 805
Retroreflective tape 805
Medical 806
Defibrillators 808
Defibrillator Heartstart Frx including Pads And Softcase 808
Medical Oxygen Systems 809
Med Ox system IMO, Outside Excl mox-40 cylinder 809
Med Ox system. IMO Bedside Excl mox-40 cylinder 810
Med Ox System IMO, Norwegian type Excl mox-40 cylinder 811
Medical Oxygen Resuscitators 812
Oxygen resuscitator without cylinder 812
Medical Suction Unit 813
Environmental 814
Oil spill products 816
Oil spill Kits 816
Oil spill care and maintenance tools 817
Oil spill kit spare storage box 818
Oil spill kit spare 1000 l waste bag 818
Sorbents & Booms 819
Spill Kit Sorbent Pads 819
Sorbent Rolls 820
Sorbent particulate U94 821
Sorbent sweep U941800 822
Sorbent Pillows 823
Sorbent Booms 824
WTS Safety Systems 826
Maritime Logistics 852
Ships Agency 854
Terms and conditions
WSS Product Catalogue.pdf
Download [13 KB]
Wilhelmsen Ship Service Product Catalogue - Wilhelmsen [2017, PDF]
Related hand tools | Изображения и названия инструментов на английском [PDF]
TOOLS, valves & MATERIALS For Marine use - Kazi Md. Abu Sayed [20??, PDF]
The time now is: Today 14:16
