zxc ®   09-Oct-2012 19:54
Изображения и названия инструментов на английском / Related hand tools
Publisher: -
ISBN: -
Quality: OCR without errors
Number of pages: 9
Description: This file contains images and names of most of the hand tools used on the ship.
В этом файле приведены изображения и названия большинства ручных инструментов используемых на судне
Tools list
RELATED HAND TOOLS
BALL PEIN HAMMERS
SOFT FACE HAMMERS
RUBBER MALLET, Hiskory Handle DEAD-BLOW SOFT FACE HAMMERS
SCRAPPER, Forged Shank, Chrome Plated COPPER HAMMERS, Hiskory Handle
FLEXIBLE SPRING CLAW, Chrome Plated RIVET BUSTER, BLACK FINISH
INSPECTION MIRRORS, Chrome Plated,
Cushion Grip
ALIGNING PUNCH
PINCH BARS, BLACK FINISH ROLLING HEAD PRY BARS, BLACK FINISH
PRICK PUNCHES SOLID PUNCHES
CAPE CHISELS PIN PUNCHES
COLD CHISELS – EXTRA LONG COLD CHISELS – STANDARD LENGTH
LONG TAPER PUNCHES DIAMOND POINT CHISELS
HALF ROUND CHISELS CENTER PUNCHES
BRICK RAKING
CHISEL
STONE MASON’S
CHISELS
WOOD CHISEL COMB & COMB
HOLDER
SCALING CHISEL BUSH HAMMER
HEAD &
HOLDER
CHASING BIT &
HOLDER
SOFT FACE HAMMER
TIPS
BLADE TYPE FEELER GAUGE SETS
WIRE TYPE FEELER
GAUGE SETS
SCREWDRIVERS
ROUND SHRANK, CUSHION GRIP SQUARE SHRANK, CUSHION GRIP
PHILIPS, CUSHION GRIP CABINET (ELECTRICIAN’S) STYLE, CUSHION
GRIP
ROUND RANK, CLEAR HANDLE SQUARE RANK, CLEAR HANDLE
PHILIPS, CLEAR HANDLE CABINET (ELECTRICIAN’S) STYLE, CLEAR
HANDLE
HOLLOW SHAFT NUT DRIVERS ROBERTSON STYLE, CLEAR HANDLE
SCREW STARTER FOR SLOTTED HEAD SCREWS SCREW STARTER FOR PHILLIPS HEAD SCREWS
OFFSET SCREWDRIVERS,
STANDARD TIP
PHILLIPS TIP
6 METRIC
HEX KEYS
7 METRIC HEX KEYS
A- RATCHET
B- HINGE HANDLE
C- EXTENSION
D- EXTENSION
E- EXTENSION
F- FLEX EXTENSION
G- SPEEDER
H- T-HANDLE
PLIERS, CUTTERS, NIPPES
TONQUE & GROOVE PLIERS
Plain
handless
Cushion
grips
TONQUE & GROOVE IGNITION PLIERS
Plain
Handless
Natural
Finish
Cushion
Grips
Chrome
Plated
BENT NEEDLE NOSE PLIERS
Plain
handless
Cushion
grips
LONG SLIM NEEDLE NOSE PLIERS
Plain
handless
Cushion
grips
AVIATION SNIPS CUTTER/CRIMPER PLIERS
BRAKE SPRING PLIERS
Cadmium
Plated
LOCK RING PLIERS
RETAINING RING PLIERS TERMINAL CLAMP SPREADER & REAMER
BATTERY PLIERS COMBINATION SLIP JOINT PLIERS
FLAT NOSE
PLIERS
With
WIRE
CUTTER
CHAIN NOSE
PLIERS
with
WIRE
CUTTER
LINEMAN’S PLIERS
Plain Handless
Cushion Grips
ROUND NOSE PLIERS
Plain handle Cushion Grips Cushion Grips with
Spring
PLIERS
Insulated
Grips
Pliers
Cushion Grips
with Wire
Stripping
Notches
Regular Cut – all cutting
pliers, except those
designated Flush Cut
Flush Cut
STRAIGHT CUTTING
SNIPS
CIRCULAR CUTTING
(DUCKBILL)
SNIPS
END CUTTING NIPPERS
Cushion Grips with
spring, Flush Cut
Regular Cut Regular Cut
PIPE TOOLS
PIVOT ARM
PIPE CUTTER
Malleable
Iron
Frame
FOUR WHEEL
PIPE
CUTTER
CHAIN
PIPE TONG
with
Double End
Jaws
CHAIN
PIPE TONG
with
Single End
Jaws
PIPE WRENCH
Offset pattern
PIPE WRENCH
Straight
Pattern
THREADING
SET
with NC Bolt
Dies
THREADING
SET
with NPT
Pipe Dies
TUBE FLARING NPT PIPE 800 SERIES
TOOL TAP DIE HEAD
RATCHET
REAMERS
WRENCHES
OPEN END WRENCHES COMBINATION WRENCHES
15o & 75o ANGLE WRENCHES DOUBLE END TAPPET WRENCHES
15o BOX
WRENCHES
45o BOX
WRENCHES
COMBINATION FLARE NUT WRENCHES DOUBLE HEAD FLARE NUT WRENCHES
RATCHETING BOX WRENCHES ADJUSTABLE WRENCHES
REGULAR PATTERN BOX WRENCHES (12 Point
opening)
STUB END BOX WRENCHES – STRAIGHT
PATTERN (12 Point opening)
T-HANDLE SOCKET Hexagon
WRENCHES Opening
OFFSET
SOCKET
WRENCHES
STRIKING FACE BOX WRENCHES STRIKING FACE BOX WRENCHES – 45o OFFSET
12 Point opening
ADJUSTABLE HOOK
SPANNER WRENCHES
PIN SPANNER
WRENCHES
ADJUSTABLE
FACE SPANNER
WRENCHES
FACE SPANNER
WRENCHES
CROWFOOT ATTACHMENTS
Box Open End
Thin
Pattern
Pump
wrenches
T – SLOT NUT HEX NUT & WASHER
SOCKETS
6-POINT
OPENING
SOCKET
8-POINT
OPENING
SOCKET
12-POINT
OPENING
SOCKET
FLEX
SOCKET
EXTRA
DEEP
12-POINT
OPENING
SOCKET
SPECIAL
SPARK PLUG
SOCKET
With
RUBBER
INSERT
STUD REMOVER SCREW-DRIVER
“DRAG LINK”
SOCKET
UNIVERSAL
JOINT ADAPTER
¼”F
3
/8” M
RATCHET
SPINNER
RATCHET
ADAPTER
PLUG
CONNECTOR
PLUG
ADAPTER
HEX SQUARE SHANK HEX DRIVER SOCKET
PHILLIPS
SCREWDRIVER SOCKET
STANDARD
SCREWDRIVER SOCKET
SCREWDRIVER,
MICROMETER
ADJUSTABLE
TORQUE WRENCHES
DIAL TORQUE WRENCH REVERSIBLE RATCHET
DEFLECTING BEAM TORQUE WRENCH RATCHERING HEAD TORQUE WRENCH
Micrometer adjustable
PLAIN HEAD TORQUE WRENCH
Pre-Set
WORK-HOLDING TOOLS
SWIVEL BASE
MACHINISTS’ VICES
3-ARM/ 2-ARM CONVERTIBLE PULLERS
ELECTRICAL BEARING
PULLER
(Hub &
forcing
screw
black
finish)
BEARING & GEAR
PULLER
PARALLEL CLAMPS MEDIUM SERVICE
PATTERN
EYE BOLT
Plain
Pattern
EYE BOLT
Shoulder
Pattern
BENT TAIL
With Square
Head Screw
BENT TAIL
With
Safety
Screw
STRAIGHT
TAIL
With Square
Head Screw
PLAIN DRILL DRIFT LOOP HANDLE CRANK HANDLE
PILOT BEARING PULLER MAGNETIC RETRIEVING TOOLS
CHAFT PROTECTOR SQUARE INSERT
TOOL HOLDER
SQUARE INSERT TOOL
HOLDER (right hand)
REVOLVING HEAD
KNURLING TOOLS
TRIANGULAR INSERT
TOOL HOLDER (lefthand)
TRIANGULAR INSERT
TOOL HOLDER
CARBIDE TIPPED
BORING CUTTER
HIGH SPEED STEEL
BORING CUTTER
DRILLING TOOL HOLDER SOLID CARBIDE CHIP
BREAKERS
HIGH SPEED STEEL
KNURLS (Diamond
Pattern)
HIGH SPEED STEEL
KNURLS (Straight
Line Pattern)
BRACING VERTICAL
JACK JACK
PANEL JACK
CHUCK and ARBOR TELESCOPIC FEED
SCREW
REDUCING SLEEVE MORSE TAPER
SLEEVE
TURRET
TOOL POST
TAPERED EXTENSION
SPINDLES
BREAST PLATE
GRINDING WHEEL
DRESSER
TWIST DRILL GRINDING
WHEEL GUARD EYESHIELD SPADE HANDLE
SANDER ACCESSORIES
GRINDING
WHEEL
FG FLEXIBLE
SURFACE GRINDING
DISK
CUT-OFF WHEELS
KNOT
WIRE
BRUSH
CALICO
POLISHING
MOPS
WIRE
SCRATCH
BRUSH
CUP
WIRE
BRUSH
FELT
RUBBING
PAD
LAMBSWOOL
POLISHING
BONNET
VALVE GUIDE
CLEANER
SUSPENSION SPRING
and CHAIN
SAW ACCESSORIES
RIP AND CROSSCUT BLADE
A fast cutting blade
combination for all general
work on dry or green oak,
soft woods, hardwood.
FRICTION BLADE
For high-speed cutting of
corrugated steel sheets,
etc.
CROSSCUT BLADE
Recommended as for rip
and crosscut blades where
fine finish is required.
ALUMINIUM CUTTING BLADE
Special temper and with
formation for high-speed
cutting without clogging.
COMPO AND WALLBOARD SAW
BLADE
A fine-toothed blade for
cutting wallboard,
composition sheet including masonite,
aluminium sheet, etc.
PLANER AND MITRE BLADE
For extremely smooth finish
to rip and crosscut work.
Suitable for cutting lead
as well as the above
mentioned timbers.
ABRASIVE DISK
SILICON CARBIDE - For
cutting flat or corrugated
asbestos sheets, stone,
brick, etc.
ALUMINOUS OXIDE - For
cutting cast iron, steel tubes or
sheet, etc.
Special 30 Tooth Rip and Crosscut Blade
Of thicker gauge than standard and has a
tooth with deep gullet. Used for cutting
harder types of timber, especially
builders, planks encrusted with plaster
or concrete, etc.
FLOORING BLADE
Special temper for cutting occasional nails in reclaimed timber, crates etc.
English_Tools.pdf
Download [729 B]
zxc ®   09-Oct-2012 19:58
Если честно я и русских названий не знаю у многих инструментов. Обычно, когда приходишь к точиле, спрашиваешь у него что-то вроде "Дай мне вон ту *ерню для того-то того-то..."
kolyan1982   10-Oct-2012 09:02
devilfish   10-Oct-2012 11:05
Надо выпустить книгу с названием "Названия инструментов на русском(Всякая х-я!)" Смех
3
Ottche256   28-Mar-2014 12:23
Смех смехом)))А когда картинки с инструментами для палубы,показывают машине в Marlins Test,вот это жара.Если на русском не знаешь как называется,куда там английском.Не переводить же все одной фразой-some fuck Стена
__D__J__   19-Jun-2016 10:07
Хороший сборник слов, но без перевода на русский - теряет всякое значение
TOOLS, valves & MATERIALS For Marine use - Kazi Md. Abu Sayed [20??, PDF]
Wilhelmsen Ship Service Product Catalogue - Wilhelmsen [2013, PDF]
How to Grind Lathe Tool Cutter Bits - South Bend Lathe Works / Правильная заточка токарных резцов…
Machinery’s Handbook (29th Edition) - Erik Oberg, Franklin D. Jones [2009, PDF]
Desmi self-priming centrifugal pump Modular S / Operation and maintenance instruction [2003, PDF]
The Best Seamanship (A Guide to Deck Skills) [2012, PDF]
The time now is: Today 16:04
