Nemo ®   19-Jun-2025 05:23
TOOLS, valves & MATERIALS For Marine use
Year: 20??
Author: Kazi Md. Abu Sayed
Pages count: 38
Description: A practical handbook created to support regular machinery maintenance aboard ships. It emphasizes essential spare parts, tools, and materials that must be kept onboard—and explains their selection and usage to ensure proper upkeep and efficient inventory control.
“Tools, Valves & Materials for Marine Use” by Kazi Md. Abu Sayed is a comprehensive manual for marine engineers and shipboard technical staff. Addressing the core needs of ship maintenance operations, the book is divided into three main sections:
Tools – Thorough review of hand tools essential for maintenance tasks, such as wrenches, pliers, saws, hammers, and pullers. Each tool category is explained with context-specific usage guidance.
Valves – Detailed explanations of marine valve types including gate, globe, check, relief, and ball valves. The guide outlines their operational principles and application in systems like cooling, ballast control, bilge, and firefighting.
Materials – Guidelines for selecting appropriate materials for marine environments, focusing on corrosion resistance and meeting regulatory standards, ensuring durability in harsh sea conditions.
Designed as a go-to reference, this manual helps engineering teams maintain equipment efficiently, understand stock requirements, and ensure readiness with the right tools and materials onboard.
8.1 Maintenance Tools
  • 8.1.1 Hand Tools
    • Hand Spanners / Wrenches (Fixed, Adjustable, Pipe Wrenches)
    • Pliers (Combination, Long Nose, Cutting)
    • Hammers (Ball Pein, Claw, Soft Face)
    • Screwdrivers (Flat, Phillips)
    • Allen Keys / Hex Keys
    • Pullers (Two-jaw, Three-jaw)
    • Hack Saws
    • Chisels and Punches
    • Files and Rasps
  • 8.1.2 Power Tools
    • Electric Drills
    • Grinders (Angle, Bench)
    • Cutting Machines
    • Welding Machines
8.2 Valves Used Onboard
  • Gate Valve
  • Globe Valve
  • Non-Return / Check Valve
  • Relief Valve
  • Ball Valve
  • Butterfly Valve
  • Quick Closing Valve
8.3 Materials Used in Marine Engineering
  • Ferrous Metals (Cast Iron, Carbon Steel, Stainless Steel)
  • Non-Ferrous Metals (Bronze, Brass, Copper, Aluminium)
  • Alloy Steels and Special Purpose Materials
  • Gaskets and Sealing Materials
  • Greases, Lubricants, and Packing
8.4 Storage and Inventory Control
  • Tool Identification and Storage
  • Material Preservation Techniques
  • Maintenance Inventory Checklist
TOOLS, valves & MATERIALS For Marine use.pdf
A Practical Guide to Piping and Valves for the Oil and Gas Industry - Karan Sotoodeh [2021, PDF]
Related hand tools | Изображения и названия инструментов на английском [PDF]
Applied Welding Engineering. Processes, Codes, and Standards - Ramesh Singh [2016, PDF]
KR PSC Checklist Guidance - KR Register [2024, PDF+MP4]
LaQue’s Handbook of Marine Corrosion - David A. Shifler [2022, PDF]
Maintenance Welder: Passbooks® Study Guide - National Learning Corporation [2019, PDF]
Inventory of Hazardous Material Maintenance Manual - Synergy Group [2020, PDF]
Machine Guarding Safety (Safeguarding) Course [2024, MP4]
Oxy-arc underwater cutting recommended practice - IOGP [2023, PDF]
Fire Safety Systems (FSS) Code - IMO [2015, PDF]
The time now is: Today 14:25
