zxc ®   17-Aug-2013 20:34
Framo Documentation / Equipment, Technical data, System drawings
Year: 2005
Author: FRANK MOHN AS
Genre: Documentation
Publisher: FRANK MOHN AS
Number of pages: 150
Description: FRAMO DOCUMENTATION
XXX
No XXX
Date: XX.XX.2005
Rev.:
Yard: SHIP / xx, XX
Hull no.: XXX
Ship owner: Germany
Classification: GL
CONTENTS
Chapter 1 EQUIPMENT
Chapter 2 TECHNICAL DATA
Chapter 3 SYSTEM DRAWINGS
Chapter 4 SPECIAL INSTRUCTIONS
More...
FRAMO SPECIFICATION 0240-0753-4
CHAPTER 1 EQUIPMENT
GENERAL ARRANGEMENT DRAWING NO.: 0287-1782-1
POWER PACK UNIT W / EQUIPMENT
1 1 A56260-GL HYDRAULIC POWER UNIT 0345-2071-3
7 1 A32122-GL COOLING WATER ACCESSORIES 0300-1114-2
A32122-GL
TRANSFER UNIT W / EQUIPMENT
10 1 A26288 OIL FILLING / TRANSFER UNIT (WITH STARTER) 0344-1021-2
11 5 3015799 SNAP ON COUPLING 0247-0849-3
12 2 A676 FLEXIBLE HOSE W/SNAP-ON COUPLING 0247-0781-2
CONTROL SYSTEM W / EQUIPMENT
21 1 A44714 REMOTE CONTROL VALVE ASSEMBLY, 0125-0875-1
14 VALVES
22 1 A44708 REMOTE CONTROL VALVE ASSEMBLY, 0125-0875-1
8 VALVES
23 16 A38496 SETS OF CONNECT./CABLES FOR . CONTR. VALVE AND PRESS. TRANSMITTER, L = 3 M 0381-2169-3
24 6 A38497 SETS OF CONNECT./CABLES FOR . CONTR. VALVE AND PRESS. TRANSMITTER, L = 6 M 0381-2169-3
25 1 A56068 JUNCTION BOX FOR REMOTE CONTROL VALVE ASSEMBLY 0381-2837-3
26 1 A51104 EMERGENCY STOP (HYDR. SYSTEM) 0381-0782-3
27 2 A19008 EMERGENCY STOP (CARGO PUMPS) 0381-0782-3
28 1 A56061 CARGO PUMP CONTROL PANEL 0381-3693-2
35 1 A34771 EMERGENCY OVERRIDE PANEL 0381-1951-3
PORTABLE PUMP W / EQUIPMENT
40 1 A30554-GL PORTABLE PUMP TK80 0259-0329-1
FLEXIBLE HOSE, L = 18 M
42 1 A21400 PORTABLE WINCH FM400-25 0911-0444-4
43 5 A39754 NRV W/FLANGE FOR SNAP ON COUPL. 0179-0297-3
44 5 A39761 BALL VALVE W/FLANGE FOR SNAP ON COUPL. 0179-0302-3
45 1 A6818-GL RETURN HOSE, L = 18 M 0259-0337-3
47 1 41301-GL PRESSURE HOSE, L = 18 M 0253-0034-3
49 1 A7208 CARGO ADAPTER 3" ANSI 0259-0376-2
55 1 A39768 EQUIPM.FOR OPERATION OF PORTABLE PUMP 0125-0845-3
EQUIPMENT FOR CARGO PUMP
60 18 88781 SNAP-ON COUPLING 1/2" 0257-0991-3
61 4 A23399 FLEXIBLE HOSE L = 3,5 M 0257-0993-3
62 18 157065 EXHAUST TRAP 0255-0793-4
63 18 A30000 VALVE ARR. STRIP. AIR/INERT GAS 0321-0244-3
64 18 A31206 WELDING ADAPTER FOR ITEM NO.63 0321-0285-4
CARGO PUMP SD125
90 2 A27324 SET OF BOLTS AND GASKET, SD125 0366-1044-4
91 4 A10400 PUMP/PIPESTACK SUPPORT, SD125 0367-0161-2
92 2 A51526 CARGO PUMP SD125 0387-0540-4
TOP PLATE ARRANGEMENT 0387-0376-4
SPACE FOR TEMPERATURE SENSOR BOX 0387-0352-4
SUCTION WELL 0387-0546-401
0387-0546-402
ORIENTATION OF HYDR. CONNECTION: Xє
L = XXXX MM, A1 = XXXX MM
94 18 A33683 WELDING FLANGE FOR VACUUM STRIP 0367-0679-4
96 2 A12762 CARGO FLANGE,SD125 0366-0108-2
B = Ш134,7MM, C = Ш139,7 MM
99 2 A8786 DECK TRUNK, SD125 0366-0538-4
H = 500 MM (MILD STEEL)
CARGO PUMP SD150
110 10 A27325 SET OF BOLTS AND GASKET, SD150 0366-1044-4
A27325
111 20 A10160 PUMP SUPPORT, SD150 0367-0161-2
112 10 A50687 CARGO PUMP SD150 0387-0544-4
TOP PLATE ARRANGEMENT 0387-0385-4
0387-0546-402
ORIENTATION OF HYDR. CONNECTION: XXє
L = XXXXX MM, A1 = XXXX MM
116 10 3014388 CARGO FLANGE, SD150 0366-0110-2
B = Ш163,1 MM, C = Ш168,3 MM
119 10 A8790 DECK TRUNK, SD150 (MILD STEEL) 0366-0541-4
H = 500 MM
CARGO PUMP SD200
130 6 A27326 SET OF BOLTS AND GASKET, SD200 0366-1044-4
A27326
131 12 A5626 PUMP/PIPESTACK SUPPORT, SD200 0367-0161-2
132 6 A56728 CARGO PUMP SD200 0367-0975-4
TOP PLATE ARRANGEMENT 0367-0642-4
SUCTION WELL 0367-0960-4
ORIENTATION OF HYDRAULIC CONNECT: XXє
136 6 A12494 CARGO FLANGE, SD200 0367-0247-3
B = Ш213,0 MM, C = Ш219,0MM
139 6 A11641 DECK TRUNK, SD200 (MILD STEEL) 0367-0224-4
H = 500 MM
BALLAST PUMP W/EQUIPMENT
210 2 A53553 BALLAST PUMP SB200 0384-0485-4
EVACUATION SYSTEM 0384-0486-4
EVACUATION SYSTEM (SCHEMATIC) 0102-0553-4
ORIENTATION OF HYDRAULIC CONNECTION: 0°
214 2 127514 MANOMETER BRACKET (-1 TO 15 BAR) 0049-0143-2
217 2 A33840 EJECTOR 0102-0408-3
219 1 A55505 CONTROL VALVE ARRANGEMENT FOR EJECTOR 0102-0554-4
222 2 A49222 HEADER TANK FOR SB200 0384-0385-3
TANK CLEANING PUMP W/ EQUIPMENT
230 2 A32124 TANK CLEANING PUMP, 4VF1 0083-0496-2
HYDRAULIC MOTOR SIZE A2FM45
60 M3/H - 100 MWC
232 2 A11516 VALVE STC-25-S-*-P-R 0125-0469-1
144 L/MIN. - 150 BAR
234 2 A14932 MANOMETER BRACKET (-1 TO 15 BAR) 0049-0547-3
235 2 A8495 AIR SEPARATOR TANK, DN100 0049-0518-3
237 2 A33840 EJECTOR 0102-0408-3
238 2 A55505 CONTROL VALVE ARRANGEMENT FOR EJECTOR 0102-0554-4
VALVES
260 1 A24994 HEATING AND VENTING VALVE 0179-0181-3
261 10 110015 BLEED PLUG 0125-0281-4
262 14 A43395 BALL VALVE, DN32 0179-0427-3
263 3 A43394 BALL VALVE, DN25 0179-0427-3
264 6 A43396 BALL VALVE, DN32/38 0179-0427-3
269 3 A11515 NON RETURN VALVE, DN30 0179-0021-3
270 14 A11514 NON RETURN VALVE, DN40 0179-0020-3
272 6 A11560 NON RETURN VALVE , DN50 0179-0033-3
ELECTRICAL STARTER
300 3 A56069 STARTER MAIN POWER PACK 0381-3694-3
303 1 A56073 STARTER FOR JOCKEY PUMP 0381-3695-3
304 1 A26330 STARTER FOR TRANSFER PUMP 0381-1289-4
TOOLS, SPARE PARTS, TEST EQUIPMENT
310 1 A47861 TOOLS: STANDARD 0032-0357-4
SD125/SD150 0032-0495-4
SD 200 0032-0475-4
TK80 0032-0456-4
4VF1 0032-0382-4
OIL COOLER 0032-0373-4
311 1 A57200 TEST KIT 0247-0970-3
A57200
312 1 A31576 SET OF SPARE PARTS A31576
313 1 A48275 SET OF RECOMMENDED SPARES 0294-1552-4
DUMMY W/ EQUIPMENT
320 1 A52731 LASER 0208-0733-4
321 1 A57618 DUMMY EQUIPMENT SD125 0208-0668-4
322 1 A57619 DUMMY EQUIPMENT SD150 0208-0668-4
323 1 A57620 DUMMY EQUIPMENT SD200 0208-0668-4
OTHER EQUIPMENT
340 1 A57621 HYDRAULIC PIPING SYSTEM
CHAPTER 2 TECHNICAL DATA
TECHNICAL SYSTEM DATA 0076-0713-4
PUMP SPECIFICATION FOR PUMP TYPE SD200 (CARGO) 0115-0867-401
PUMP SPECIFICATION FOR PUMP TYPE SD150 (CARGO) 0115-0867-402
PUMP SPECIFICATION FOR PUMP TYPE SD125 (CARGO) 0115-0867-403
PUMP SPECIFICATION FOR PUMP TYPE SB200-T 0115-0867-404
PUMP SPECIFICATION FOR PUMP TYPE TK80 0115-0867-405
PUMP SPECIFICATION FOR PUMP TYPE 4VF 0115-0867-406
PERFORMANCE DIAGRAM FOR PUMP TYPE SD200 0169-1392-4
PERFORMANCE DIAGRAM FOR PUMP TYPE SD150 0169-1912-4
PERFORMANCE DIAGRAM FOR PUMP TYPE SD125 0169-1393-4
PERFORMANCE DIAGRAM FOR PUMP TYPE SB200-T 0169-2186-4
PERFORMANCE DIAGRAM FOR PUMP TYPE TK80 0169-0668-4
PERFORMANCE DIAGRAM FOR PUMP TYPE 4VF 0169-1395-4
HYDRAULIC DIAGRAM,POWER PACK ROOM 0216-1409-101
HYDRAULIC DIAGRAM, DECK 0216-1409-102
HYDRAULIC DIAGRAM, POWER UNITS 0216-1406-1
FLUSHING DIAGRAM 0108-0670-1
BLOCK DIAGRAM 0222-4812-2
INTERCONNECTION DIAGRAMS 0222-4813-3
EX. CERTIFICATES
PTB 01 ATEX 1105 0294-1248-4
(EMERGENCY STOP BUTTONS ON DECK & ENGINE ROOM)
PTB NO. 99 ATEX 2083 0294-1249-4
(EX. AMPLIFIER FOR SWITCHES)
DMT 02 ATEX 203X 0294-1462-4
(EX. AMPLIFIER FOR BALLAST LEVEL SWITCH)
TUV 02 ATEX 2069 FTW3X 0294-1494-4
(EX. BALLAST LEVEL SWITCH)
FRAMO MOUNTING INSTRUCTION Separate volume
TABLE FOR CORRESPONDING MATERIAL STANDARD 0113-0024-4
FRAMO_CD_2005
Download [19 KB]
China ship building quality standard [2005, PDF]
The time now is: Today 16:52
