skipper3362 ®   05-Aug-2019 18:34
Marine v12.1
Year: 2018
Version: SP4.29
Developer: AVEVA
64-bit OS compatibility: yes
System Requirements: AVEVA Marine v12.1 SP4.29 / System Requirements
- OS: Windows XP Professional SP3 or Windows 7 Professional or Enterprise SP1 (32-bit or 64-bit)
- CPU: Intel x86 or x64 compatible - a modern, high end CPU architecture with high performance in each of the processor cores.
- RAM: 4 GB of high speed RAM; 6 GB recommended for latest workstations using DDR3 RAM, especially for Windows 7 64-bit.
- HDD: The use of two SATA-300 RAID HDDs is recommended where projects are stored on the local machine.
- Display: High resolution widescreen display recommended (1920 x 1200); dual screens also supported. Minimum resolution 1280x1024.
- Graphics: nVIDIA Quadro or similar.
- File System: NTFS
- Network: Gigabit Ethernet (GbE) LAN
- Firewall: Microsoft ICF disabled (see Workstation Notes below)
- Other:
1. Mouse - 3 button with scroll wheel
2. DVD drive - DVD-ROM will be used for media distribution.
3. Microsoft Visio 2007/2010 32-bit Standard edition (for AVEVA Diagrams)
4. Microsoft Office 2007/2010 32-bit (for Excel import/export, Schematic Gateway and Reporting)
5. Arial Unicode MS font (supplied and installed with MS Office)
6. Adobe Acrobat Reader
Crack: Included
Description: AVEVA Marine is an integrated suite of software for the design and construction of every type of ship and offshore project. Using powerful object-centric technology, it is the most productive engineering software solution available for the marine industries. Transform your capabilities, production quality and profitability with the most powerful and integrated solution for naval architecture, hull and outfitting design, manufacturing and production planning, developed over more than 30 years in partnership with the world’s leading shipbuilders.
The enhanced reporting options offer an efficient tool, with an enriched User Interface, enabling sharing across many of the AVEVA Marine modules and other AVEVA products. The new and improved capability means that users are able to create report templates via a wizard and can insert images and charts, making it easier to use with a more professional presentation. Users benefit through the standard model library allowing the ability to reuse designs from existing built-in complex components, reducing the man-hours spent on the design.
Extended language support features and extended data exchange capabilities meet the requirements of AVEVA’s global customer base, offering greater flexibility in multi-location projects involving different simultaneous languages. There is also greater flexibility when working within an Integrated Engineering & Design environment due to the automatic creation of symbolic-type marine drawings from the model database, as well as general 2D drafting functions.
AVEVA’s Integrated Engineering & Design approach offers users’ entry points to a wealth of other products. AVEVA Engineer products create schematics, diagrams, datasheets, naval architecture, engineering lists and indexes. The AVEVA Design products create 3D models for detailed design and produce all associated deliverables. AVEVA’s Manage products enable global work share, clash management and design review.
AVEVA Marine v12.1 SP4.29 / Installation Guide
1. Download the software first and then unzip it.
2. Disconnect system access to the Internet.
3. Enter int\t80294\MARINE1214 and by running the Setup.exe file, AVEVA Hull & amp; Install outfitting.
4. Enter int\t52160\GLOBAL121SP4 and install the AVEVA Global Server software by running Setup.exe.
5. Enter int\t80303\M_IMPLANTSTL150 and install AVEVA ImPLANT-STL by running Setup.exe.
6. Enter int\t80304\M_IMPLANTI230 and install AVEVA ImPLANT-I by running Setup.exe.
7. Enter int\t52174\PMLPUB22 and install AVEVA PML Publisher by running the Setup.exe file.
8. Enter the update\Marine12.1.4.29 path and update the software by running the Marine12.1.SP4.29.exe file.
9. Enter the Crack\AVEVA Licensing v1.3 folder and install AVEVA Licensing System by running Setup.exe.
10. Run the AVEVA Licensing Client Configuration Tool from the C: \ AVEVA\AVEVA Licensing System\ALSClientConfigTool.exe path with Administrator access.
11. In the User Environment and System Environment section, complete the Server 1 values ​​according to the following pattern.
12. In port number 4545 and in the hostname enter the localhost entry.
13. Click Save Settings and then Close.
14. Run the AVEVA License System Console application from the C: \ AVEVA\AVEVA Licensing System\ALSConsole.exe path with Administrator access.
15. Enter the Start/Stop tab.
16. Click Start Licensing System.
17. Enter the Keygen folder and right-click on the Keygen.exe file and click Run as Administrator.
18. Make a file named lservrc.xml alongside the Keygen file.
19. Enter the Licenses tab.
20. Type the Browse button and give the file's address the lservrc.xml.
21. Click Install License File.
22. In the window that opens, click Start License File Installation.
23. Enter the Query/Config tab.
24. Make sure the RMS Server is green in the Query option.
25. Run the original software.
26. Sign in with your username and password XXXXXX.
27. The software is fully functional and can be used without any limitations.
Tips
- This software has been fully tested with Cracked. .
- If you encounter an active & creation error, enter the Computer Name value instead of localhost, by right-clicking on the computer and choosing the Properties option.
- This software requires Microsoft .NET Framework 3.5/4.0 and Microsoft Visual C ++ Runtime to run correctly
- All files are compressed and repaired as much as possible I WinRAR is able to & be.
password  www.p30download.com
aveva marine v12
Download [15 KB]
DELFTship Free v.18.10 (360) - DELFTship Maritime Sofware [2026]
BOCA Suite v.2.2.0.3 - AVEVA [2018]
MATLAB R2025b v.25.2.0.2998904 x64 (Windows) - MathWorks [2025]
AVEVA Review 12 v.2.0.11 - AVEVA [2018]
Seafarer: The Ship Sim v.0.3.0.1797 (Build 23027061) - Astragon [2026]
World Ship Simulator v.04.11.2016 - Odin Game Studio [2016]
TimeZero Navigator v.4.2.0.133 - Nobeltec & MaxSea [2022]
Kelvin Hughes SharpEye X-Band Radome Radar KH-1650 Installation Termination & Maintenance Handbo...
eSail Sailing Simulator v.1.5.31 - eSail [2023]
HMC ECDIS v.5.1 [2014]
The time now is: Today 03:01
